Old 05-05-2020, 12:04 PM #16
SpecialJ SpecialJ is offline
SpecialJ is on a distinguished road
Originally Posted by AuSeeker View Post
My advice is that your engine is toast, sorry, I also think if not done at a Toyota dealer you should be able to get a used engine for around $1200 to $2000 and then labor on top of that would run about the same, so anyone quoting you more than say $4500 max is just trying to make money off of your misfortune.
That being said even if you get the engine replaced for a reasonable amount or any amount for that matter, you could still end up with other issues soon after or over time if the job is not done properly, so IMHO I would try and sell your T4R and get another one with a good history.
Also before any blame is placed on your mechanic, I want to try and get you to clarify about the "oil on the spark plug", did the plug have oil on the tip of the plug where the spark occurs or on the threaded portion of the plug as in the following photo??
If the oil was only on the threads as in the photo, then it wasn't due to a "valve seal" but instead it was due to the spark plug tube gasket and not a major issue, the spark plug gasket is a part of the valve cover gasket set, which is a BIG difference than a "valve seal", to replace the spark plug tube gasket which would be done while replacing the valve cover gasket is not a major nor costly job and shouldn't have caused the issue you now have, now a valve seal replacement would be a more complicated and costly job, which would require removal of the engine head to do and if not done properly as mentioned could of caused your issues.
How much did your mechanic charge you to replace the "valve seal" this would be very telling on what he actually did?
You're right, it was a gasket seal and it was on the threads like you stated. I got mixed up and tbh I still don't completely understand all the parts of the engine (I'm learning!) so you're right, it was a pretty minor and cheap job.
SpecialJ is offline   Reply With QuoteReply With Quote
Old 07-14-2020, 02:44 PM #17
750ml 750ml is offline
750ml is on a distinguished road
How did you resolve your problem?
750ml is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 12:04 AM #18
RickyAdventure RickyAdventure is offline
RickyAdventure is on a distinguished road
Originally Posted by SpecialJ View Post
Thank you, this is sound advice. I called my local mechanic in AZ and they said they could find an engine with 110k miles but everything included would still run around 7000 to replace. That mechanic told me to try and dump it on a dealer for trade. With the car market dropping, does that maybe mean sell mine ASAP, then buy another a little later?
Gimp Audacity Blender
I wonder if driving up and down in the "Rockies" had something to do with the destruction of your 4runner V6. Those mountains can take a toll on a car or truck IMO.
RickyAdventure is offline   Reply With QuoteReply With Quote
back , engine , miles , oil , sensor
Repair head gasket, replace engine, or replace truck? backcountrylimo 3rd gen T4Rs 25 06-01-2020 05:25 PM
Should I replace this CV Axel (less than 500 miles on it) MarkBlack 3rd gen T4Rs 19 12-14-2019 04:45 PM
Engine Whine - mechanic wants to replace my power steering pump at 70k miles Mike2005v8 Maintenance/Detailing 7 05-02-2017 11:48 AM
Should I replace LBJs? - they only have 75K miles jacob7071 3rd gen T4Rs 11 11-12-2013 06:59 PM
Replace front rotors after 30,000 miles? Dansnare Maintenance/Detailing 18 09-13-2006 01:16 AM
