Originally Posted by Davidsmith7
On my 15 limited would I have to change the studs to run 1” spacers? Is it safe to run shorter studs?
The stock limited 20" wheels would work fine with 1" spacers. All 4Runners have the same studs. The Limited OEM wheels have recesses in between where the mounting surface areas are around the holes for the lug nuts. So they clear the longer studs even though the longer studs protrude further than the surface of the spacer. Kinda hard to explain, but pretty obvious if you look at the back side of your Limited wheels.
I don't have a handy picture of a limited wheel - but here's a different OEM wheel. You can see how there are pockets where the longer studs would otherwise interfere. That's how Limited wheels are.
