Old 05-20-2020, 12:24 PM #1
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Harbor Freight Recall
if you use the harbor freight 6 ton or 3 ton jack stands....dont till you check
the 6 tons #61197 and the 3 ton 56371 or 61196
they have found to be able to collapse....ouch...your dead
near 2 million jack stands are being recalled
Old 05-20-2020, 01:17 PM #2
swampdodo swampdodo is offline
swampdodo has a spectacular aura about swampdodo has a spectacular aura about
DIYer's...Take Note.
article link here
swampdodo is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 02:28 PM #3
mcat707's Avatar
mcat707 mcat707 is offline
Real Name: MURDERED TRD
mcat707 has a spectacular aura about mcat707 has a spectacular aura about mcat707 has a spectacular aura about
mcat707's Avatar
04/11/2020
Discussed here...
Harbor Freight Jack Stands - Failure/Recall
mcat707 is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 02:34 PM #4
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
I wonder how they fail exactly.
If the problem is with the vertical support breaking a tooth or the locking mechanism failing, the vertical support will just fall until it hits the concrete in which case the vehicle is still held a foot above the ground unless it slides off.
If the problem is with the leg supports, yeah you're screwed if one of those give way.
I have 2 of the 6 tons that are under recall. Most of the time I leave the floor jack underneath as well so I don't sweat too much.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 03:17 PM #5
mcat707's Avatar
mcat707's Avatar
This guy would know...
https://www.toyota-4runner.org/3471536-post13.html
Old 05-20-2020, 03:20 PM #6
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
And this is why I always keep the jack, jack stand & rims tires under there.
Single point of failure is asking for trouble.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 08:14 PM #7
Tucson4runner's Avatar
Tucson4runner Tucson4runner is offline
Tucson4runner will become famous soon enough
If your job or your life depend on it, don't but harbor freight.
Sent from my SM-N975U using Tapatalk
work in progress
Tucson4runner is offline   Reply With QuoteReply With Quote
Old 05-20-2020, 10:10 PM #8
Originally Posted by Tucson4runner View Post
If your job or your life depend on it, don't buy harbor freight.
work in progress
Old 05-20-2020, 10:30 PM #9
sn_85's Avatar
sn_85 sn_85 is offline
sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold sn_85 is a splendid one to behold
sn_85's Avatar
Same here. Lift jack, jack stands, and wheels under the frame just to be sure.
2016 Nautical Blue Metallic Trail | SCS | Falken Wildpeak AT3/W | Icon CDCV | Heftyfab Front Bumper | 4x4 Labs Rear | Shrockworks Sliders | RCI Skids | Warn VR10S | OGE Dual Battery System | sPOD | Katzkin
2013 Blizzard Pearl LE 4WD - SOLD!!!
sn_85 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 05:58 AM #10
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Kinda been my thoughts for years. I will use the HF air wrench to pull the tire off but not use their stuff to support the truck. The problem is finding dependable jack stands but I have two sets from the 80's so i am probably good
Ghostrider is offline   Reply With QuoteReply With Quote
freight , harbor , jack , stands , ton
Harbor Freight Jack Stands - Failure/Recall BobsTrail 5th gen T4Rs 70 11-03-2020 09:39 AM
Harbor Freight Recall....danger 3bears 3rd gen T4Rs 64 09-11-2020 04:42 PM
PSA: Harbor Freight jackstand recall 08TxRunner 5th gen T4Rs 10 04-08-2020 12:21 PM
Harbor freight Bed liner MadeInMaine 5th gen T4Rs 4 01-22-2016 04:42 PM
Harbor Freight 25% off Today only Dagwoods 5th gen T4Rs 0 03-31-2013 08:12 PM
