Old 05-21-2020, 06:42 PM #1
TOYOTA 09 TOYOTA 09 is offline
TOYOTA 09 is on a distinguished road
Maintenance Schedule?
Hello all! i have 45K on my wife's Runner(2015 Trail Premium) and I'm tackling some of the larger maintenance items. I have always rotated the tires, and changed oil and filters every 5K since the truck was new. I recently replaced the tires and Brake pads/rotors, as well as cabin filter and engine filter. next on the list will be drain and fill the front and rear diffs as well as transfer case.
my question is where can i find the suggested schedule for all this? my manual only says "inspect and replace if necessary" for the diffs, transfer case, transmission.
besides the engine oil/filter change (Every 5K) my plan was to do the drive line fluids and transmission every 50K...service manual says nothing about plugs?
TOYOTA 09 is offline   Reply With QuoteReply With Quote
Old 05-21-2020, 06:56 PM #2
edit, i found plugs in the maintenance guide to be changed at 120K....but nothing about DIFFs and trans fluid changes..i am definitely going to change the front/rear diff and transfer case fluid (what should i use for that) should i even bother changing the transmission fluid at 45K? if not when should i?
Old 05-21-2020, 07:13 PM #3
spartacus's Avatar
spartacus's Avatar
here is a helpful link
Soliciting opinions/facts re major fluid changes
Old 05-25-2020, 08:33 PM #4
Bossman's Avatar
Bossman Bossman is offline
Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light Bossman is a glorious beacon of light
Bossman's Avatar
Fluid Change Interval
Fluid Change Intervals (Other than oil)
Diff and Transfer Case oil change at 40-45k?
Front and Rear Diff fluid change
Transmission Service
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
Bossman is offline   Reply With QuoteReply With Quote
filter , maintenance , schedule , tires , transfer
5th Gen T4R Maintenance Schedule Beerguy20144R 5th gen T4Rs 3 08-18-2020 11:52 PM
Maintenance Schedule Sandpiper 5th gen T4Rs 7 01-07-2014 01:29 PM
maintenance schedule? triangles 3rd gen T4Rs 2 10-07-2010 12:46 PM
Maintenance schedule? Calickr Classic T4Rs 0 05-07-2010 09:55 PM
'04 Maintenance Schedule? wwilme 4th Gen T4Rs 1 03-16-2007 02:11 PM
