Old 05-28-2020, 02:29 PM #1
hawkcharmer's Avatar
hawkcharmer hawkcharmer is offline
hawkcharmer is on a distinguished road
Tacoma soft front brake lines on 3rd gen 4runner?
My steel brake lines coming from caliper are severely corroded and the rubber hose going to frame needs to replaced too.
I heard of people using Tacoma soft lines and bypassing the steel caliper line, all the way up to frame (one continuous line)
Does anyone have part numbers on the front Tacoma soft lines?
I have 99 4runner with tundra brake upgrade.
Any feedback is greatly appreciated!
1999 4Runner SR5, 3.4L 5VZ-FE V6 | Tundra/890 coils | 5100 Bilsteins all around l 199mm Tundra brake upgrade | 265/75/16 Falken Wildpeak AT3 tires | ARB Bull Bar
hawkcharmer is offline   Reply With QuoteReply With Quote
Old 05-28-2020, 08:01 PM #2
kyrin kyrin is offline
kyrin is on a distinguished road
Try camelbacktoyota parts website
kyrin is offline   Reply With QuoteReply With Quote
Old 06-03-2020, 12:08 AM #3
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Had to go out and try it out of curiosity. It should work in theory by the look of it. The Tacoma banjo bolt screws into the threads on the 4runner caliper without issues and clamps down far enough as well.
You will obviously need more than the line itself. You'll also need the banjo bolts, copper washers for them and the brackets that attach the brake lines to the spindles.
You'll want to make sure that the surface on the caliper where it bolts up is clean and free of imperfections. It may need to be sanded smooth. Remember that it wasn't intended to be used as a mating surface for a seal. Also be careful routing the line as the Tacoma calipers have the line come in at a different angle and there wont be any provision to locate the line on the calipers.
Part numbers I'd use would be centric 15044064 and 155044065. About 10$ ea on rockauto. Could be a good time to upgrade to stainless lines too if you wanted too. They're not terribly expensive.
I'm no good at finding the OEM numbers for the other specific little parts. A Toyota specific wrecking yard is where I'd head but a good parts guy could probably get you everything new.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
brake , frame , lines , soft , tacoma
Generation 3 front brake calipers/pads/rotors AND New braided front brake lines Capnemo For Sale: T4R Items 0 07-01-2019 01:08 PM
recommendations for braided front brake lines 2ndhandyotaman 3rd gen T4Rs 2 08-09-2018 08:59 AM
Front Brake Hard Lines Bumbo 4th Gen T4Rs 4 01-19-2017 05:34 PM
For those who have replaced their rear heater lines with soft lines? Blanco 3rd gen T4Rs 3 04-13-2013 09:57 AM
Front brake lines PitbullRescuer 3rd gen T4Rs 3 12-21-2011 05:40 PM
