Old 06-09-2020, 06:49 PM #1
alvisjus's Avatar
alvisjus alvisjus is offline
alvisjus is on a distinguished road
alvisjus's Avatar
Mounting RTT to Rhino Rack Using Front Runner QD Mounts
Hello all,
First of all, I am no expert and this modification was not specifically recommended by Front Runner or Rhino Rack. I did this at my own risk and if you choose to try this modification, I am not responsible for any failures.
I am posting this because I struggled to find any information on what I was wanting to do. My goal was to see if anyone had mounted a RTT to a Rhino Rack pioneer platform using Front Runner's QD mounts. If you haven't checked them out, they are awesome, but they are meant to go on Front Runner racks, not other racks. Because of this, the mounting hardware was unusable with my solution to mounting on the Rhino Rack.
Quick Release Tent Mount Kit - by Front Runner
My solution was to buy the following Rotopax mount from rhino rack because it included the plates that fit into the mounting grooves of the rack.
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1371-jpg
I did not use the bolts from either the Rhino Rack mounting kit or the Front Runner kit. The reason is I wanted stainless steel bolts for the added strength and the rhino rack bolts were too small. I ended up going with a 3/4" stainless steel button head bolt with M8 x 1.25 threading. In the picture, left is the new bolt, right is the bolt that comes with the rotopax mounting kit.
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1372-jpg
Because of the difference in size, I used a drill press and a 6.9mm or 17/64" drill bit to drill out a hole big enough for tapping with an M8 x 1.25 hand tap.
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1365-jpg
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1368-jpg
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1366-jpg
Lastly, I used the bolt with a split ring washer and mounted the Front Runner mounts to the Rhino Rack pioneer platform.
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1373-jpg
Mounting RTT to Rhino Rack Using Front Runner QD Mounts-img_1375-jpg
The mounts are super strong and I have no doubt it will be strong enough. I can mount and unmount my tent by myself in only a couple minutes. It is absolutely worth the price of admission. Let me know if you have any questions!
Silver 2020 TRD Off Road Premium - 3" Toytec BOSS Aluma Series Suspension- Nitto Ridge Grapplers - Icon Alloys Vector 6 Wheels - CBI Full Skids and Rock Sliders - Rhino Rack Pioneer Platform with Backbone - CVT Rooftop Tent
alvisjus is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 07:13 AM #2
4rnrGunner 4rnrGunner is offline
4rnrGunner is on a distinguished road
I like the smart thinking you had on this idea.
4rnrGunner is offline   Reply With QuoteReply With Quote
Old 10-27-2020, 04:36 PM #3
xkevin303x xkevin303x is offline
xkevin303x is on a distinguished road
Curious if you had any issues getting an allen wrench in there with the tent on or if you mounted the mounts first and then slid the tent feet portion into place? Also, looks like two Rotopax kits need to be bought or is there 8 plates in one kit?
xkevin303x is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 04:03 PM #4
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing is on a distinguished road
GhostRing's Avatar
I'm surprised they offer those plates and not the square versions, since those do not appear to rotate into position like they do on the underside of the trays?
One possible helpful variant if one is looking for just your style plates with a larger bolt hole is: Rhino Rack part N024-BP
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 06:41 PM #5
OffroadRN OffroadRN is offline
OffroadRN is on a distinguished road
Great info. I just spent two full days installing my RTT on the Pioneer backbone and cursing at Rhino-Rack for not having a quick release solution. After the Moab trip in March, I am definitely taking the time to attempt this mod!
OffroadRN is offline   Reply With QuoteReply With Quote
Old 02-22-2021, 08:12 PM #6
KDMcD KDMcD is offline
KDMcD is on a distinguished road
Great information! Thank you.
KDMcD is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 11:58 AM #7
Overland6751 Overland6751 is offline
Overland6751 is on a distinguished road
Thanks for this post! I also have a Rhino Rick Pioneer platform and have been looking all over for a solution to add a quick release for my IKamper. It sucks that Rhino Rack doesn't make these to fit with their racks, but I'm going to order the Front Runner brackets and follow your instructions. Any further tips or tricks you could pass along would be helpful!
Overland6751 is offline   Reply With QuoteReply With Quote
Old 02-26-2021, 12:31 PM #8
Also wondering if ordering these channel nuts from McMaster would fit inside the rack channel instead of having to buy the Rhino Rack/Rotopax channel nuts and drilling them out. It is pre-drilled for M8 1.25. They seem to be a lot cheaper option as well. Any thoughts?
McMaster-Carr
Old 02-26-2021, 10:04 PM #9
GhostRing's Avatar
GhostRing's Avatar
McMaster-Carr
Those should work as I believe Rhino plates of that design are 5/16" (~8mm) thick
Heck, try to find some without the serrated grooves and they may be even cheaper...
Build Etc...
Old 03-09-2021, 01:44 PM #10
Elvir555 Elvir555 is offline
Elvir555 is on a distinguished road
This is great, when i had my rhinorack platform on my jeep i used those channel locks and directly mounted the tent to the rack flat and that was a pain lining it up and getting into the rack channels. This seems like a much easier method.
Elvir555 is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 01:46 PM #11
McMaster-Carr
As long as you get the correct size they will work. I ordered from them a while back and have been using them on my rent too. Much cheaper than the rhinorack ones.
front , mounting , rack , rhino , runner
**FS: 5th Gen 4Runner Rhino Rack Backbone with Platform low profile rack - N. GA** Terrapod For Sale: T4R Items 2 03-09-2020 10:42 PM
Little help between Front Runner or Rhino Rack JKRunner 5th gen T4Rs 35 11-17-2019 09:03 PM
FS San Diego- Rhino Rack roof rack, Thermarest pad, Tacoma fog light switch nytosc For Sale: Non-T4R Items 0 02-11-2018 07:06 PM
Front Runner full length roof rack. First production run rack install. Apex Overland 5th gen T4Rs 59 06-04-2017 08:47 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
