06-12-2020, 02:02 PM
Reverse camera view on Pioneer ND-BC8 back up camera and AVH-2550NEX, any way?
Put in a new Pioneer AVH-2550NEX head unit last week. I previously had an older Kenwood DDX-471HD (from 2014) and had installed a Pioneer Nd-Bc8 back up cam on rear with the Kenwood. I had settings to be able to reverse images on the HU as needed.
My new Pioneer was installed with existing backup camera with proper image for the back up camera. I am happy with the cam so I ordered another for the front. Put it in last night but the image is reversed left to right (mirrored). There is not a setting on the HU I’m seeing to switch nor on the camera. I called Pioneer and they said I’d have to purchase a different brand camera made for the front that doesn’t automatically mirror the images.
Is there a way to reverse the image that anyone knows about? Maybe a setting or something I’m missing? Am I able to modify the camera or wiring somehow? I’d prefer not to have to unphish all the wiring and reinstall/phish new wiring? Any suggestions or help?
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
06-22-2020, 02:41 AM
Anybody???
If not, what are you guys running for a front camera where the image is not automatically mirrored? Recommendations?
06-22-2020, 08:46 AM
check page 87 in the manual. im looking through it, something with camera view, or av input.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
06-22-2020, 08:57 AM
might want to try alpine
Alpine | HCE-C2600FD
but check out youtube for fivestarcarstereo , they have videos of camera installs, im not sure what they use for front cameras tho, but they have done it before.
06-22-2020, 07:16 PM
Real Name: Jeff
Real Name: Jeff
I have a set up similar to what you are trying to do. I have a Pioneer AVH4200NEX and use the same ND-BC8 as my back-up camera, but used a different one for the front. Looking in my stereo user's manual you should be able to reverse the mirrored image (see below) and IIRC I've seen that option screen.
This is what I show in my Pioneer user's manual:
1 Display the “System” setting screen.
Refer to Displaying the “System” setting screen on page 45
2 Touch [Camera settings].
3 Touch [Back Camera: Reverse Video] to switch “On” or “Off”.
I'm thinking you want to select "2nd Camera" here
If you don't see the "Reverse Video" option when selecting the Front Camera I wonder if that's because there is no reverse wire input to that camera so that option isn't enabled?
FYI....this is the camera I use for the front view (NATIKA 720P Backup/Front View Camera)
Amazon.com: NATIKA 720P Backup/Front View Camera, IP69K Waterproof Starlight Night Vision High Definition and Super Wide Angle Reverse Rear View Backup Camera for Cars Jeep Trucks SUV RV Van: Car Electronics
Hope you get it sorted.
2001 4Runner SR5 4x4, V6 Auto, ME Silver|2nd Owner|5 Stars with 265/75/R16 Falken Wildpeak AT3Ws
4.88s w/ front and rear ARB lockers|Shrockworks front bumper, rear bumper with swing out, and rock sliders|Tundra TRD Pro springs and Bilstein 5100s|OME 890 springs and Bilstein 5100s|SS Fully Adjustable Trac/PanHard Bar|SS Diff drop|TBU – 13WL calipers w/ Stoptech slotted rotors|Prinsu full length roof rack|Smittybuilt X20 winch|ARB CKMA12 compressor
Reason: correction
06-23-2020, 02:57 AM
I’ve scoured through that thing many times but checked again, not an option to reverse the mirrored image unfortunately.
I don’t have those options available. It’s either back camera on or off. When on it triggers the reverse cam and automatically pops up on the screen, off it does nothing. I don’t have a second option for front camera really. It asks about the AV for a camera or video source (or something similar to that). Messed with this setting as well. Only thing it does is that when I’m in camera view mode for the rear view I can toggle from camera 1 to camera 2 by pushing the camera toggle button on the lower right side of screen.
I’m wondering even if it did have a “reverse image” option if it would only apply to the rear view anyways and may not work, even with my prior Kenwood?
So on the Nakita, is the image mirrored as a std? Or do you have to reverse the image on your unit to get the orientation proper?
That camera is certainly a pricey one lol, plus it looks like it will need another control box for it. I may consider another HU if I can’t get this sorted out, thank you for the response though.
06-23-2020, 01:05 PM
Real Name: Jeff
Real Name: Jeff
Another thought...... have you checked the firmware version or checked it there is an firmware update for your HU? Just trying to think of another option that may resolve enabling those camera options.
https://www.pioneerelectronics.com/S..._CVJ4858-D.zip
For the Nakita camera I don't remember needing to reverse the image.
I do remember cutting one of the wires so that the lane markers did not show.
Reason: addition
06-23-2020, 07:37 PM
That’s a good suggestion about the firmware, I figured it was the newest since I just got it. It looks like I have V18.11 but there is a V1812 available now. So 2 questions.
1-I don’t have a computer, is it possible to do with an iPad or another way?
2-does it state anywhere that defines what the newest firmware version update adds?
The Nakita camera has 2 looped wires it says. The blue, which if you cut removes the parking guidelines and talks about if you use it for a front camera to cut the white wire loop. I’m assuming that is what reverses the image by leaving the white wire looped, and cutting it keeps the image the same?
06-24-2020, 08:07 AM
if you want to save money, you might need to get the cheap ebay ones, look for the one where you can cut the loop wires to reverse the image.
the good cameras are the cmos ones right?
have you look into kenwood?
06-24-2020, 12:54 PM
Real Name: Jeff
Real Name: Jeff
1. I think you'll need a computer because you need to get the extracted firmware file onto a USB storage device which you plug into your HU. If you can figure out how to do that with an iPad that will work.
https://www.pioneerelectronics.com/S...n.11-11-19.pdf
2. Yes, on this page https://www.pioneerelectronics.com/P...port/Downloads, if you select the "Firmware Update Notice" link for the AVH-2550NEX it calls out that it fixes "No sound from rear speakers when resuming music after finishing a call." Here's the notice
https://www.pioneerelectronics.com/S...r.11-11-19.pdf
Regarding the Nakita camera.... I may have cut more than one of the wires and probably did per the instructions, but it's been a while since I did it so don't remember which ones.
Reason: links incorrect
