Old 06-29-2020, 01:53 PM #1
I4CUTigers I4CUTigers is offline
I4CUTigers is on a distinguished road
Solution to front bumper corner popping out?
Was curious if anyone ever found a good solution to the front bumper and it’s tendency to pop at the corner near the headlight?
I had my bumper replaced due to someone hitting me and the replacement bumper tabs on the new bumper are very malleable on the passenger side, so every time I pop it in, it immediately pops out. The driver side is more rigid, and therefore the tabs hold into the female coupler just fine.
I was wondering if there is any way to make the plastic injection line where the tabs rest any stiffer, which should cause the tabs that rest on that protruding line to function correctly by holding in the female coupler.
Thank you
I4CUTigers is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 02:12 PM #2
shadow247 shadow247 is offline
shadow247 will become famous soon enough shadow247 will become famous soon enough
Originally Posted by I4CUTigers View Post
Was curious if anyone ever found a good solution to the front bumper and itís tendency to pop at the corner near the headlight?
Thank you
Did they use an OEM or Aftermarket bumper? Either way, I would be driving back to the shop and asking them to fix it. It should not be popping out unless you hit something. Either the bumper is bad, the tabs on the bracket are bad, or something is wrong with the fender alignment. I have 20 years experience in the body shop, it should not have been delivered if they couldn't keep the bumper snapped in.
2001 LIMITED 4X4 - Fresh as a Daisy at 196k! - Bone stock and staying that way! (not likely)
99 SR5 Sport - 387k and rolling! Front - Toytec 3/4 Spacer/Tundra Shocks. Rear - Daystar 1.5" Spacer/LC Shocks - FOR SALE - PM ME
shadow247 is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 02:27 PM #3
According them, it’s an OEM bumper (which it appears to be), but there are reports of new off the lot 4r’s with the same issue. The problem from me removing it and examining the bumper, is that the injection mold is too thin On the line where they Mold the tabs. When the tabs click into the female coupler on the vehicle, any outward force (like clipping the rest of the tabs in place), causes that flimsy injection molded line to bend, which cause the tabs to lose good contact with the female coupler. If that line was firm, those tabs would be fine.
The real issue is a poorly designed bumper tab system. It’s just not robust enough to hold in that corner unless absolutely perfect.
Old 06-29-2020, 03:04 PM #4
pDubs's Avatar
pDubs pDubs is offline
pDubs is just really nice pDubs is just really nice pDubs is just really nice pDubs is just really nice
pDubs's Avatar
https://www.toyota-4runner.org/3157496-post24.html
from thread: Front Bumper to Fender Separation
2014 SR5 Premium
5100s w/Dobinsons 2.5/1.5" springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 10:48 PM #5
That is exactly what I would try. You may need to clean with Alcohol prior to using the 2 sided tape. There are 2 versions of the tape out there, you want the Red backed roll with grey/black adhesive for Automotive. Oreilly and Autozone sell some small pieces, but if you go back to your shop and show them the thread, I bet they will hook you up for nothing.
Old 06-30-2020, 09:09 PM #6
Thanks!
bumper , line , pop , solution , tabs
Rear Bumper Repair Solution 370HSSSV 5th gen T4Rs 21 08-14-2015 08:00 PM
FS: 3rd gen Running Boards, Corner Lights, Front Corner Lights NASHVILLE, TN jaredking733 For Sale: T4R Items 1 03-20-2015 05:49 PM
Rear Bumper Solution FFRC 4th Gen T4Rs 6 01-14-2011 06:42 PM
popping front end? rdgt4r 3rd gen T4Rs 5 02-09-2009 11:06 PM
Popping in front end??? 4runningyota 3rd gen T4Rs 20 04-20-2007 09:02 PM
