Old 07-17-2020, 10:31 AM #16
cwilliams563's Avatar
cwilliams563 cwilliams563 is offline
cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about cwilliams563 has a spectacular aura about
I’ve been using PB blaster on my rusted 4Runner bolts as well, way more than I care to mention. It’s ridiculous! Kroil is a great penetrant as well, we use it at work. Spray before hand and let it sit.
One great piece of advice that I received from a long time mechanic is once you get the bolt to break free, while loosening if there is ANY resistance turn back the other way, spray again and then try to loosen. Keep going back and forth as needed. It is very time consuming, especially since every seized bolt I have seems to be an inch longer than it needs to be, ugh. That’s kept me from twisting off and breaking even more bolts than I already have which is a fair amount.
My build thread https://www.toyota-4runner.org/4th-g...ml#post3520544
2008 Titanium Metallic 4WD 4Runner V6 SR5| Satoshi Grille mod|17x8 Level 8 MK6 wheels, 275/70/17" Falken Wildpeak tires| Front-Bilstein 5100's set at 0 with ToyTec branded Eibach silver springs and 1/2" ToyTec spacer driver side, 1/4" ToyTec spacer passenger|Front Diff. drop spacer kit|sway bar relocate kit| Rear-Fox 2.0Resi and ToyTec superflex black springs|Tyger Bull bar with LED's/Lund HX tube side steps
2021 Subaru Crosstrek Limited in Crystal White Pearl
cwilliams563 is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 11:03 AM #17
PaulC4 PaulC4 is offline
PaulC4 will become famous soon enough PaulC4 will become famous soon enough
Good luck in solving the issue.
The video that the original poster mentioned was this one:
Which Penetrating Oil is Best? Let's find out! - YouTube
That video is interesting, not only from the conclusions, but also from the rigorous home-brew scientific approach to testing. His (Project Farm Channel) other comparison videos show similar originality.
I wound up choosing Liquid Wrench + time, based on his comparison.
That was to deal with a rear shock bolt going upwards into the frame of a 2004 Jeep Wrangler, where the head snapped off and the sheer point was inside the frame. (Almost a perfect storm of worst-case). So, in addition to the penetrating oil this required some drilling upside down at an odd angle, plus a good quality 'EZ Out'.
At least I didn't have to resort to taking the body off of the frame to remove this bolt...
Rusted on nut methods ?-20200606_170017-jpg
PaulC4 is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 02:32 PM #18
rwh963 rwh963 is offline
rwh963 has a spectacular aura about rwh963 has a spectacular aura about
Originally Posted by Traveler74 View Post
Pardon ? What do you mean ?
yes, just a little humor!
rwh963 is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 02:33 PM #19
i advocate the "back and forth" method as well. forcing it forward will usually end up breaking the bolt. penetrating fluid, back and forth, and go slow.
Old 07-17-2020, 03:33 PM #20
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
Heat
I was watching a video disassembling model A engine and they were using one of these around the 2:0 minute mark. Too expensive probably for your situation but it does work.
Ford Model A 4-cylinder engine rebuild time-lapse | Redline Rebuilds - S3E4 - YouTube
How to remove rusted bolts or nuts in less than a minute - iDtools
With a torch you will need to heat it to red in order to have heat work.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 10:17 PM #21
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
WOW! That is one very bent bolt. You must have worked hard to get it out.
Traveler74 is offline   Reply With QuoteReply With Quote
Old 07-17-2020, 10:56 PM #22
Not quite as bent as it appears in the picture. Trying to figure out the angle to drill into the broken bolt from underneath was a challenge, and I was pretty happy to get it close to the correct alignment. When I pulled it out, I found I'd only just barely grazed the threads of the receiving captive nut. Chased the opening with a tap, and the replacement bolt went in smoothly.
Hopefully you don't have to go to these extreme measures.
As other folks have mentioned, a good penetrating oil (not regular WD-40) + time + plus some vibration/shock/back&forth hopefully will be the ticket to solving your issue. The exact brand of oil (because everyone has their own favorite) may be less crucial than the time to penetrate factor. The one from this picture took me two weeks to take out. Much of that time was allowing the oil to soak in, the rest was in figuring out some new words to add to my already extensive "automotive vocabulary"...
Old 07-18-2020, 03:15 AM #23
yes, I am letting the nut/bolt soak in penetrating oil for 3 days so far. Looked today for Liquid Wrench but it was no where to be found.
Dr. says it'll be another 10-12 days before I can use my right wrist again, so no time is wasted by letting the nut/bolt soak.
At minimum, I'll remove the radiator plastic shroud to give me more room to work.
Old 07-23-2020, 12:02 AM #24
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
My rusty trusty 1977 FJ40 likes it when I use Mouse Milk.
Rusted on nut methods ?-dd61a9cd-ff3e-46c6-890f-56149ffd40ee-jpg
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Jpilot is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 01:58 PM #25
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
We use talon rust breaker at work and i will spray bolts a few days before tackling something on the truck. usually heat and in/out method with a impact gun get most bolts out.
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 02:34 PM #26
NicoBg NicoBg is offline
NicoBg is on a distinguished road
i met a lot of rust bolts when working on mine, i used heat to remove them and works like a charm, then after heating them, i rest them in white vinegar for 1 night and brush them following day with iron brush, most get back to a fantastic shape
NicoBg is offline   Reply With QuoteReply With Quote
Old 07-27-2020, 03:25 PM #27
I finally got that stubborn nut off the alternator locking bolt. Sprayed WD-40 on it twice/day for a week. Even then I had to use a 12' breaker bar.
Thanks, guys for all the tips.
Old 08-07-2020, 04:42 AM #28
jackbouer jackbouer is offline
jackbouer is on a distinguished road
There is a Toyota dealer, that I COULD have the T4R towed to , but their prices for such work is completely open ended.
fast auto clicker
jackbouer is offline   Reply With QuoteReply With Quote
locking , nut , plan , rusted , spays
Best price for methods stolen417 5th gen T4Rs 5 06-19-2020 02:26 PM
Methods or FNs or? jmferg 3rd gen T4Rs 25 04-02-2019 08:35 AM
WTT Methods for Mickey Thompsons 4Runner010 For Sale: Suspension/Wheels/Tires 1 05-31-2016 07:20 AM
New methods to adding Aux Input? JSeligman2828 4th Gen T4Rs 20 02-17-2016 04:36 PM
Engine Flush Methods nilson Maintenance/Detailing 3 06-13-2011 06:22 PM
