Old 07-19-2020, 07:42 PM #1
Texas_4Runner Texas_4Runner is offline
Texas_4Runner is on a distinguished road
Normal Alternator Output
I had to jumpstart my 4Runner so I drove it to O’Reilly’s and they said my battery was good and the voltage regulator failed.
I drove home, charged my battery to full, cleaned the terminals that were filthy. This morning it struggled to start but I was able to get back to O’Reilly’s. A different person told me the battery was bad. It’s over 3 years old so I put in a new one.
Then they tested the alternator again and said the voltage regulator still failed. I went home and used a multimeter and got the following numbers.
With 4Runner off 12.78V
@idle No lights 13.46V
@2000 rpm no lights 13.55V
@idle with lights 13.42V
@idle with headlights, radio, and AC on high 13.36V
I’m supposed to drive to MT tomorrow and I don’t really want to put in a cheap remanned Ultima alternator from O’Reilly’s. Based on those numbers the alternator seems to be working. And I don’t hear a whine.
It’s a 2008 V8. What are your thoughts? Should it be closer to 14V?
2008 V8 LTD
Texas_4Runner is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 08:02 PM #2
itr1275 itr1275 is offline
itr1275 has a spectacular aura about itr1275 has a spectacular aura about
First off the guys at O’Reilly’s get about 10 mins of training on this stuff, but they do have better equipment than a volt meter.
It is remotely possibly the the entire electrical charging system went bad at the same time. I've never seen nor heard of it but it "could" happen. i.e. they likely don't know what they are doing.
The numbers look about right it should be about 13.5-14V when charging. I doubled checked my 2020 4runner 5 mins ago and it's 13.9V while charging. The video below shows 14.5 - All the Toyota's I have had run < 14V.
Take a look at the voltage when you start the car too. The battery voltage will drop. Anything below 9-10V can be an issue with the battery.
Check it when you turn it off. Battery voltage should be ~12.5V. Let it sit overnight and check the voltage again. If it's dropped below 12 it's likely a battery.
This should help.
How to Test a Car Battery with a Multimeter - YouTube
itr1275 is offline   Reply With QuoteReply With Quote
Old 07-19-2020, 08:04 PM #3
BTW you might try a different O'Rielly's or different source. The quality of customer service reflects 100% on the management.
Best of luck stay safe.
Old 07-19-2020, 08:36 PM #4
Thanks.
The perk to living in the middle of no where is having only one auto store, and it’s O’Reilly’s.
2008 V8 LTD
Old 07-19-2020, 09:25 PM #5
SilverFox2020 SilverFox2020 is offline
SilverFox2020 will become famous soon enough
If you have access to a load tester, that will tell you about battery condition and alternator performance. A battery may show 12 volts but not have the reserve to turn your starter. Extreme heat and cold shortens battery life.
SilverFox2020 is offline   Reply With QuoteReply With Quote
Old 07-23-2020, 12:13 PM #6
Lester Lugnut's Avatar
Lester Lugnut Lester Lugnut is offline
Lester Lugnut has a spectacular aura about Lester Lugnut has a spectacular aura about
12.60V at the battery is passing if the vehicle has been at rest for 8 hrs.
But...voltage is only part of the story.
Take vehicle to a real repair shop for analysis. As previously stated, O'Reilley and other mass marketers have better equipment than most DIY types, but know little or nothing compared to an ASE cert. tech.
2015 2WD Toyota Tacoma Prerunner V6 SR5 1GR-FE 236HP VVT-i
2014 2WD Toyota 4Runner SR5 1GR-FE 254 HP Dual VVT-i
2006 Toyota Avalon 3.5l automatic 2GR-RE Dual VVT-i
1991 Mercedes-Benz 300-SEL M103
1975 Kawasaki 900 Z1-B
Lester Lugnut is offline   Reply With QuoteReply With Quote
Old 07-25-2020, 09:18 PM #7
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
its easy to test the battery for dead cell.
meter the battery during cranking, if it dips below 11 or 10 its bad.
factory alternator should push out 13.4 on hot running. 14 on cold.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 07-30-2020, 03:08 PM #8
duffdog duffdog is offline
duffdog is a jewel in the rough duffdog is a jewel in the rough duffdog is a jewel in the rough
If the charge light is not on in a Toyota, the alternator is working fine. All Toyota alternators made since 1978 are internally regulated, there is no external "voltage regulator" to break.
It sounds like you just need a new battery. If the battery has not been load tested...do that first.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
duffdog is offline   Reply With QuoteReply With Quote
Old 08-01-2020, 06:55 PM #9
Twilghtzone Twilghtzone is offline
Twilghtzone is on a distinguished road
Battery testers are pretty cheap on Amazon. Start at....er... $6.
Seems like you can get a pretty good one for $50 or so.
Twilghtzone is offline   Reply With QuoteReply With Quote
@idle , alternator , battery , lights , o’reilly’s
High Output Alternator slimboiphat 3rd gen T4Rs 17 10-22-2021 07:59 PM
Alternator output? mewallis 5th gen T4Rs 13 06-05-2016 11:05 PM
WTB 4th gen 4.0 High Output Alternator Rocket61 Want to Buy/Trade 1 02-28-2016 10:59 PM
Higher output alternator dorton Classic T4Rs 14 08-23-2013 04:59 PM
Stock Alternator Output?? deckert4r 3rd gen T4Rs 0 07-18-2006 10:23 PM
