Old 08-29-2020, 03:42 PM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Best basic radio for driving on logging roads?
I was driving on an FSR the other week and for the first time had a loaded logging truck coming down - it was easy to see+pull off to the side, but I realize that isn't always the case.
What are my options for the most basic setup so I can hear the logging trucks? I've heard of the Baofung UV-5r?
I don't really want an "installed system" given the INfrequency that I go on those roads, and don't otherwise do offroading/overlanding.
With something like the Baofung would I be able to hear the trucks coming down given the twists+turns around the mountain landscape, the trees surrounding the road, etc.? Something else I should be considering?
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 06:27 PM #2
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
The Baofeng UV-5r is a Ham Radio, do you have a Ham license? If so and assuming the loggers are on a Ham radio it would work depending on the distance and obstructions. Although the BaoFeng BF-F8HP is a more powerful alternative for not much more.
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 06:42 PM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
How To Program Your Radio for BC’s Backroads | West Coast Placer
Maybe helpful.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 08-29-2020, 07:17 PM #4
PlzSellMeA4Runner PlzSellMeA4Runner is offline
PlzSellMeA4Runner is on a distinguished road
I never would have guessed you need a license to use a ham radio. the more you know I guess.
PlzSellMeA4Runner is offline   Reply With QuoteReply With Quote
Old 09-09-2020, 11:44 PM #5
LimeLED's Avatar
LimeLED LimeLED is offline
LimeLED will become famous soon enough LimeLED will become famous soon enough
LimeLED's Avatar
Technically, you can listen without a license. You need the license to transmit. In the scenario OP mentioned, listening might be enough.
2023 4Runner TRD Pro, Midnight Black
2022 4Runner TRD Pro, Lime Rush
2022 4Runner TRD Off-Road Premium, Magnetic Gray (SOLD)
2018 4Runner TRD Off-Road Premium, Super White (SOLD)
LimeLED is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 09:21 AM #6
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Ability to transmit is priceless in many situations. Get licensed and not worry.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 09-10-2020, 12:24 PM #7
photo8 photo8 is offline
photo8 is on a distinguished road
Logging trucks probably aren't on amateur (ham) frequencies, which by their nature, are non-commercial. It's possible they could be bootlegging amateur frequencies, but more likely they are on commercial frequencies or CB radio (or both).
The Baofeng can be programmed to receive commercial frequencies in the VHF and UHF bands, but NOT CB which is AM and in the 27 MHz band.
Another alternative for receive only is a scanner. They can be programmed to receive pretty much any frequency, including commercial, ham and CB.
You might take a look at Radio Reference (RadioReference.com - Scanner Frequencies and Radio Frequency Reference) and ask you question there. RR is radio and scanner oriented and you have a good chance of getting more specialized advice, including which specific frequencies you will need to monitor.
photo8 is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 12:01 PM #8
Iffykid Iffykid is offline
Iffykid is on a distinguished road
Originally Posted by BackOff View Post
This and a $30 Baofeng UV5R would allow you to monitor the freq's used once programmed into the radio.
If the provided stubby antenna does not provide acceptable reception you could also add a $20 NAGOYA NA771 antenna or for max reception a $35 NAGOYA UT-72 rooftop magnetic mount antenna.
If you wish to transmit on said freq you may be required to have a license as I am not sure on the Canadian freq usage.
Dollar amounts are in USA funds not sure about Canadian pricing.
Iffykid is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 03:38 PM #9
speedmaster speedmaster is offline
speedmaster is on a distinguished road
Get yourself a Tech license, it's not that hard. But as an aside, I'm assuming that the logging trucks aren't using amateur radio frequencies, or at least shouldn't be. In the U.S. I don't think they can be used legally for any commercial purposes.
I'm hoping that if/when I get a 4Runner to put a mobile 2 meter radio and antenna in it.
speedmaster is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 08:53 AM #10
If you already had your tech license you would already know the answer to the use of Ham Band for commercial purposes as it is on the test.
The OP was asking about the logging trucks in British Columbia when driving on FSR roads they use a specific set of freq's regulated by the BC government, These freq and there use is covered in the above link provided by BackOff
baofung , basic , coming , hear , logging
Please help vsc engages while driving straight on dry roads MICA4R Problems & Warranty Issues 20 02-18-2021 04:42 PM
driving a T4R in harsh environments (salt/potash mine roads) Steamfitter General Discussions 9 05-17-2017 04:15 AM
Basic CB Radio questions Ghostrider 5th gen T4Rs 4 01-26-2017 11:04 AM
North East Trails,Logging roads 4RZ Off-Roading 0 08-14-2015 09:50 AM
Creeking noise while driving on bumpy roads luckatheirish 5th gen T4Rs 13 04-04-2013 03:25 AM
