Old 09-12-2020, 03:17 PM #1
FXFRunner FXFRunner is offline
FXFRunner is on a distinguished road
Alignment question: worn camber and caster bolts?
Hi everyone,
I just installed a 3 inch lift kit with the stock UCA's and ran into the common issue of running out of caster adjustment.
The tech at Firestone was saying that my alignment bolts were spinning but not changing anything so I should get new ones.
Before I run and start ordering parts I wanted to check if this makes any sense to any of you who have experience with this stuff.
Is it possible that the camber and caster bolts weren't doing anything because there is no adjustment left in the UCAs?
Is there really such thing as these bolts being worn?
FXFRunner is offline   Reply With QuoteReply With Quote
Old 09-12-2020, 08:33 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You don't give your mileage but if anything worn out in that area probably the bushings the bolts ride in rather than bolts. Your cam tabs could be flattened somewhat aggravating the situation.
Old 09-13-2020, 06:18 AM #3
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Unless your 4R has high mileage and lots of abuse, it's probably just that they are at the limit of adjustability. I have only a small lift up front, and can only get 2.9 caster at best.
Caveat- It could also be the tech at Firestone. I have been to Firestone 3 times in 2 months trying to get them to do a proper alignment, and each time they find a new way to mess it up.
Deuxdiesel is offline   Reply With QuoteReply With Quote
Old 09-14-2020, 02:09 AM #4
Yeah the guy didn't seem like the most knowledgable. I showed him the cam bolt kit and asked him if I need 1 or 2 of these and he seemed confused.
The car has 147k and not abused at all. No rust either. I'm guessing its at the adjustibility limit as you have mentioned.
At 2.9 caster, do you feel anything weird in the way the car drives or handles?
2007 V8 Limited / Toytec & Bilstein 3 inch lift
Old 09-14-2020, 05:15 AM #5
At 2.9 it is merely acceptable on the highway but want to follow the crown a bit, on secondary roads and dirt roads it's not noticeable. Given my lack of confidence in Firestone, I might try another shop as well.
Old 09-14-2020, 04:16 PM #6
I have the lifetime adjustment deal from them sadly. Kinda wanna ask who their most experienced tech is and make an appointment with them.
Is there really no solution to this Caster angle issue short of buying a $500 UCA? I can't bring myself to spend that much cash to gain 0.6 caster angle.
Old 09-16-2020, 12:09 AM #7
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
It doesn't sound like the tech was the most knowledgeable, but if it drives good and your camber/toe are within spec don't worry about it. Caster only affects the steering wheel's return to center characteristics and will cause your vehicle to follow grooves in the road and feel "dart-Y" when steering if it's too far off.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 05:48 PM #8
Anthonie's Avatar
Anthonie Anthonie is offline
Anthonie is on a distinguished road
Anthonie's Avatar
reply
Originally Posted by FXFRunner View Post
Hi everyone,
yes bolts can be worn out but your mileage plays a factor buying 26'' bolt joint should be installed before alignment to avoid bushing wear and tear
Anthonie is offline   Reply With QuoteReply With Quote
Old 09-16-2020, 07:33 PM #9
are you talking about lower ball joint? im confused by the 26" bolt joint comment
Old 09-20-2020, 06:00 PM #10
Anthonie's Avatar
Anthonie's Avatar
Yea I am talking about the lower ball joint,the pivot between the wheels sometimes measures around that
adjustment , alignment , bolts , caster , ucas
Caster/camber alignment cam bolts OEM or SPC? ryanlord43 3rd gen T4Rs 8 08-27-2022 03:28 PM
Alignment ( caster ) question TrdinOhio 5th gen T4Rs 5 02-28-2018 03:42 PM
Alignment Camber/Caster Kit jrm 4th Gen T4Rs 12 08-22-2016 12:33 PM
Just lifted, cam bolts are seized, can't adjust caster/camber wtcnbrwndo4u 4th Gen T4Rs 25 08-04-2016 07:18 PM
FREE: XREAS front suspension non leaking, LCA's, UCA's, camber alignment bolts T101 For Sale: Suspension/Wheels/Tires 5 01-29-2016 06:04 PM
