Old 09-13-2020, 05:00 PM #1
Emil1999 Emil1999 is offline
Emil1999 is on a distinguished road
1999 4runner won’t rev pass 3000k
New to the channel. I have this friend from work he’s selling his 1999 toyota 4runner limited 4wd 129000mils new tires everything works. He’s asking $2800 but the problem is that it has the symtom of not passing over 3000 rpms. I’m been reading a lot about the problem. I took it to toyota dealerships for diagnostic, bad cat $3000 almost $4000 How are used prices in your area?. Took the car home removed cat and 2 o2 sensors up and down strim is doing the same. New tps same problem. Clean throttlebody No changes at all. Maf sensor clean. Coil pack, cables and spark plugs good. No check engine light no codes. Timing belt water pump done at 90k. I don’t know what to do should I risked and buy it from him or back out. In my research it can be several things.
Emil1999 is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 04:06 PM #2
Anthonie's Avatar
Anthonie Anthonie is offline
Anthonie is on a distinguished road
Anthonie's Avatar
have you checked the fuel pump? sometimes when it is old it clogs and this could lead to what you just described. In my opinion would advise you not to take the risk, you should just back out perhaps you would find a deal somewhere else that will work perfectly. Hope this helps.
Anthonie is offline   Reply With QuoteReply With Quote
Old 09-22-2020, 05:55 PM #3
Chris_Overland's Avatar
Chris_Overland Chris_Overland is offline
Chris_Overland will become famous soon enough
fuel pump was my issue with the same symptoms
1999 Imperial Jade Mica Limited
Bilstein 5100 & OME 881/891
SpyderTrax 1.5 spacers
Tundra brake upgrade
238,000 and still kickin
Chris_Overland is offline   Reply With QuoteReply With Quote
Old 10-03-2020, 06:20 PM #4
Talking
1 bad coil pack and 1 bad spark plug cable, order 3 new coil pack from toyota oem, cables and spark plugs. Same problem, now I’m going for the fuel pump and filter. Thanks for the response. Going to find the problem no matter what. I already bought it.
Old 10-03-2020, 06:26 PM #5
3 Coil, ignition 90919-02212. 6 spark plugs k16tr11(90919-01192 . 1 cord set 19037-62050.
Old 10-24-2020, 01:37 PM #6
Smile Fixed
Crankshaft position sensor.
4runner , cat , clean , problem , toyota
September in Southern Colorado - Stony Pass, Cinnamon Pass, and Trout High_Country 5th gen T4Rs 30 07-13-2023 12:17 PM
WTB 1999 t4r air cleaner box and pass rear door trim Danabart Want to Buy/Trade 0 10-05-2015 12:23 AM
Wtb 3gen headlight assembly pass side, also, rear pass door white ltd. Danabart Want to Buy/Trade 0 01-15-2015 03:35 PM
Pass airbag light on with pass in seat Vwright14 5th gen T4Rs 7 10-15-2014 02:03 AM
WTB: 3rd Gen 1999 Limited pass. front fender flare yotaman75 For Sale: T4R Items 0 12-31-2012 02:08 PM
