Old 09-24-2020, 12:45 PM #1
JRod0981 JRod0981 is offline
JRod0981 is on a distinguished road
Blackout or Stealth Light Bars
Hi All,
Looking to add a light bar in the grill and really want a low profile stealth look. Been looking at 27"-30" light bars that I will mount up to an auxiliary fuse box and then an OEM style switch in the cab. I want to get it as stealth as possible behind the grill with more of a flood pattern and a color temp of 6000k to match my other lights. The DRZ bar is the most stealth looking I can find, but not really that bright and the beam pattern I am looking for.
What do you guys think of these that I nailed down? Any others I should consider that are decently priced?
Blackout or Stealth Light Bars-light-bar-jpeg
JRod0981 is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 09:12 AM #2
valleyforge.1777 valleyforge.1777 is offline
valleyforge.1777 is on a distinguished road
So, to install light bars behind the grill, one needs to be able to remove the front grill temporarily, right?
What about with the 2020 and beyond that have the radar panel in the lower front grill? Any problems with removing the grill with those models? Does the wiring for the radar sensor simply unplug and then pulg back together well, or is cutting of wires needed?
valleyforge.1777 is offline   Reply With QuoteReply With Quote
Old 09-26-2020, 01:37 PM #3
You just take off the front bumper as you need to mount brackets and such as well for the light bar in the lower grill. For the 2020 and beyond, I think you can only mount in the upper portion of the grill because of the radar panel as you mentioned. I wouldn't know if you could remove that radar panel all together.
bar , grill , light , pattern , stealth
Heise Blackout Series LED, Extreme LED Stealth or any other subdued light GA4RNR General Discussions 7 09-21-2020 12:40 PM
What kind of light bars are y'all running with your Gobi stealth racks? Bigbriman 5th gen T4Rs 8 04-05-2020 10:33 PM
Gobi stealth w/ rise and vertical bars lighting options? klum17 5th gen T4Rs 0 11-25-2017 10:51 AM
Tail light blackout DSpease15 Engines / Suspension / Wheels / Tires / Audio / Accessories 1 08-31-2011 12:35 AM
