Originally Posted by Synstars
...our 3 car garage in the home we just purchased. I need my man cave and the only available room is the garage, fine by me. I have my gym setup already in there, tools, and building a wood working section in the one care garage portion and keeping the weights and auto stuff in the double section.
I have read that the common thing to do is insulate the garage doors and make sure the seals are tight and fresh right? Makes sense to me but what else can I do over this winter to ensure that I'm not going to have another garage oven for next year?
I have access above the garage ceiling which consists of just framework and roof. I noticed that under the roof has the aluminum foil to deter heat but there is no insulation for the ceiling of the garage...step 2? Also, would spraying loose insulation in the walls provide enough insulation to deem worthy of doing?
Lastly, I have considered a mini split ac for the garage. Thoughts of electrical usage and function of one?
Thanks, as always guys, stay safe!
Where are you from, so we can understand the comparison?
If you live in Houston, cooler is not enough; you need to dry out that moist air.
You're probably going to spend $$$ to make it comfortable, it may be worth looking at replacing the door entirely with one built for purpose.
