Old 11-03-2020, 12:17 AM #1
iseeu1001 iseeu1001 is offline
iseeu1001 is on a distinguished road
do you have white smoke coming out from tailpipe?
I noticed when I bought my 4runner like a month later when I went to the back to start it up, I don't remember why I went back but anyways I know upon ever start up there is white smoke coming out instead of clear. Is there any concerns to have? I got the car at I think 44k miles and now I got 52k miles.
iseeu1001 is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 03:38 AM #2
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
White smoke can be an indication of a head gasket failure, as you would be burning coolant. If you are only seeing it for the first few minutes, it could just be steam from moisture in the exhaust system, but if it lasts longer than a few minutes, I would be concerned.
Has the truck ever overheated?
Is the coolant level steady, or are you topping off regularly?
It may be worth having a mechanic check it out.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Jpilot is offline   Reply With QuoteReply With Quote
Old 11-03-2020, 10:32 AM #3
My truck has never overheated and it turns to clear smoke after like maybe 30 seconds.
Old 11-04-2020, 06:16 PM #4
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Not sure what clear smoke is.
But it is getting colder outside. If you are not losing coolant or overheating I wouldn't sweat it.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 11-09-2020, 09:50 AM #5
mcaninch35 mcaninch35 is offline
mcaninch35 is on a distinguished road
Agreed. Keep an eye on temps and coolant level and drive!
mcaninch35 is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 01:19 PM #6
Runner-Wannabe Runner-Wannabe is offline
Runner-Wannabe is on a distinguished road
IiRC, burning coolant has kind of a sweet smell to it
Runner-Wannabe is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 06:23 AM #7
Captsolo Captsolo is offline
Captsolo will become famous soon enough
check your coolant overflow canister every morning when she's cold.
It should be at the same level.
If coolant level doesn't drop you HG is ok.
I have 2005 4runner with 150,000 miles. I can check my overflow canaster any time and at any temp and it is always the same safe level. I check mostly when cold. If it drops an inch I'd worry about HG. It has been holding exactly at the full line for 6 months or longer.
A sputter at startup is an HG indicator.
coolant out the exhaust (white smoke) is another indicator.
bubbling in your coolant from exhaust gases means HG is bad.
Captsolo is offline   Reply With QuoteReply With Quote
Old 11-15-2020, 04:57 PM #8
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
I had a 2006 Mercedes Benz C-Class for 14 years. As it got older if you started it and say drove it down the driveway and shut it off and came back later when you restarted it, it would blow out a cloud of white smoke for maybe 5-10 seconds.
It never used any oil or coolant. It had a 13,000 miles oil change interval. I think it had something to do with the catalyst.
I had a 1987 Ford pick-up with a 351. Every so often while driving on side streets it would just start bellowing white smoke. I would shut if off and restart it and the smoke was gone. I mean it would fog 3 lanes of traffic. It didn't use any more oil than would be expected. It didnt use any coolant. Again it was something with the catalyst.
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
Old 11-18-2020, 03:46 AM #9
Claypidgeon Claypidgeon is offline
Claypidgeon is on a distinguished road
What Capt Solo said plus: 1) emulsified oil means coolant in getting into the oil and the engine may get damaged, 2) besides a head gasket either the head or the block can be cracked. Much more expensive than a head gasket. 3) starting off in the morning, if you are emitting a lot of white smoke after other cars from your neighborhood have quit, you better be concerned. Like others have said, its gotta come from somewhere and the overflow will indicate.
Claypidgeon is offline   Reply With QuoteReply With Quote
back , coming , miles , smoke , start
96 4Runner SR5 white smoke coming from exhaust, black soot/liquid coming out, stalls beefsix Problems & Warranty Issues 7 05-24-2018 03:44 PM
'93 4Runner White Smoke coming from exhaust. bonzairy Problems & Warranty Issues 1 06-08-2015 02:16 PM
3vze white smoke then blackish grey smoke hoe_nah Classic T4Rs 9 10-15-2012 05:38 PM
Smoke coming from AC vents? PitbullRescuer 3rd gen T4Rs 26 07-27-2012 04:28 PM
White Smoke Coming Out Of Exhaust silverwave Problems & Warranty Issues 3 07-01-2005 03:51 PM
