Old 12-13-2020, 05:35 PM #1
Guru6022 Guru6022 is offline
Guru6022 is on a distinguished road
Did I just ruin my new agm battery
So a few months back I bought an a battery for my 4runner and it has been working great. Its winter now so it's been sitting outsidefor about a month and has been cold down to 10f at night. I go to unlock it and and nothing. I manually open the door put the key in and zero lights come on! I jump start the car move it and now the battery is on a battery tender. Have I damaged its charging potential? Have I caused some kind of permanent damage? I have a winch hooked up to it nothing else. This ruins my day a bit.
Guru6022 is offline   Reply With QuoteReply With Quote
Old 12-14-2020, 04:00 PM #2
Ogre75 Ogre75 is offline
Banned
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
Banned
Someone may be more knowledgable on these than I, but anecdotally, I have run down my AGM batteries over the years, to no dash lights or clicking, and jump started them and they were fine.
Ogre75 is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 01:07 AM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho has a spectacular aura about riceandpho has a spectacular aura about
riceandpho's Avatar
have to use a multi meter to determine the voltage of the battery first, if its below 12, use a charger to wake it up, then itll charge it back up to the proper voltage. charger with agm mode will try to charge at 14.3 to 14.7v, depending on the charger, itll bring the battery back to full if it holds charge.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofited S2000 projectors,Osram 66240CBB,Morimoto 5Five Ballast.2 pairs of Hella Supertones.Blue cluster and climate controls.Full led conversion on interior and exterior.HAWK LTS pads f+r, Stoptech slotted rotors and stainless steel lines f+r.Firestone CoilRite 4135.Bilstien 5100 @0.85, MOOG FJ Springs.
riceandpho is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:25 PM #4
weecho27 weecho27 is offline
weecho27 is on a distinguished road
Disclaimer first, I am not an expert when it comes to batteries. That being said, I have recently purchased an AGM battery for my starter battery and am looking at purchasing a deep cycle hybrid for my dual battery set up. Charging AGM batteries can be tricky in cars that weren't designed to charge them. AGM batteries require a higher charging voltage and different charging profile than your standard lead acid battery. Since your battery is somewhat new I would make sure to have your battery tested to see if there isn't a draw on it when the vehicle is turned off. If you do decide to get a battery tender/charger make sure it is compatible with AGM batteries to get the proper charging voltage and charging profile. My two cents.
weecho27 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:53 PM #5
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold Bumbo is a splendid one to behold
Bumbo's Avatar
You really need a muitimeter / volt meter. Take a reading of the battery (before recovery charging) to determine the voltage of the battery when it was dead.
That would have given you a much better indication of how far it was pushed into the ground.
The low voltage is one thing, but the longer the duration is actually a bigger concern.
At this stage all you can do it charge it and monitor it to see how it does. You can always get it tested to CCA as well.
Edit:
I feel good lead batteries can be resilient, and can handle a couple deep discharges without too much degradation. If I suspect a battery is low I always measure it first and decide what to do. If it is dangerously low, I never crank the engine and put a load on the battery; I have actually internally shorted a battery doing this making it unusable. I have also recovered batteries from very deep discharge with minimal issues, and they go back into service like normal.
Old 01-11-2021, 02:49 PM #6
superman3043's Avatar
superman3043 superman3043 is offline
Real Name: PD
superman3043 will become famous soon enough superman3043 will become famous soon enough
Real Name: PD
Check out my thoughts on this after my first picture in my post here. I can't say for sure if it's better or worse at this point, but no issues to report after about 2 and half months of running it like this.
-PD
2005 V8 SR5 4WD Natural White
My Build Thread
My "Rally Rocket" 2017 WRX
superman3043 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 06:37 PM #7
jasonbach jasonbach is offline
jasonbach is on a distinguished road
I did the same thing - I just hooked up a battery tender and let it charge for 24 hours. Battery has been fine since.
jasonbach is offline   Reply With QuoteReply With Quote
battery , car , damaged , move , tender
Did I ruin my ecm by unplugging a coil with the key in? bocephuss420 4th Gen T4Rs 4 07-15-2020 12:40 AM
Did I just ruin my CV axle? dasrowboat 3rd gen T4Rs 5 05-21-2017 03:31 PM
will headlight moisture ruin new bulbs? d_benet 3rd gen T4Rs 2 12-14-2016 05:30 PM
Did I ruin my motor? Please help!! themayce 3rd gen T4Rs 10 01-06-2013 02:16 PM
SOPA can really ruin our community here at t4r... hungryeddy 3rd gen T4Rs 49 01-20-2012 11:17 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
