Old 01-11-2021, 10:25 PM #1
KEØHZA KEØHZA is offline
Real Name: Anthony Baugh-Buys
KEØHZA is on a distinguished road
Ground switching vs power switching
Do you guys switch the ground side of a load or the power side. I eventually I will be adding all of the fun battery drainers to the runner. I know with led lights, relays are unnecessary. I will just use the appropriate amperage switch. I am just interested in how you have your electrical wired and why? TIA
2016 TEP - Stock, for now.
1997 T100 4x4 Xtra cab- SAS'd with 3 in suspension lift and 3 inch body lift on 33's soon to be 35's.
1995 T100 2x4 single cab - Stock
KEØHZA is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 12:31 AM #2
Burt Burt is offline
Burt is on a distinguished road
With respect to DC .... switch on positive. Electricity flows negative to positive.
Make sure you have proper rated fuse/breaker, switch, connections and wire gauge/insulation. Sheathing for chaffing as needed. If exposed to the elements, I suggest marine grade. Blue Sea makes some good marine hardware and can be found on Amazon.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2005 F250 SuperDuty 6.0PSD FX4 Lariat
Burt is offline   Reply With QuoteReply With Quote
Old 01-13-2021, 03:42 AM #3
JosiahHudson JosiahHudson is offline
JosiahHudson is on a distinguished road
2020 Trd off road front suspension noise?
Hey guys! I have a 2020 4Runner trd off road w/kdss and I’m wondering if anyone has the same clunk I’ve been dealing with. Coming from owning a Jeep Wrangler, hearing clunks are usually an indication somethings loose and has to be tightened before it does further damage. The noise I’ve been chasing only happens at low speeds when off roading, usually on fire roads. It’s only up until recently I noticed when I have it loaded down with a roof top tent, awning, roof rack that it’ll make the noise pulling into my parking structure after a 20 minute commute.omegle xender
I can only dig up so much on forums, and seems to be that the KDSS makes a noise when you’re driving below 12mph and the sound is usually just the hydraulic piston pushing up and down as the suspension cycles, so that would explain it off road. But hearing on road is what concerns me.
The car has 7000 miles on it and when I took it to the dealer last week, I rode with the master technician in order to get me to recreate the sound again, but I explained everything to him as I did above. He said he retorqued what he could without dismantling anything to deep, and lubricated everything too.
JosiahHudson is offline   Reply With QuoteReply With Quote
ground , power , side , switch , switching
Switching oil? Captain 3rd gen T4Rs 20 10-16-2018 09:31 AM
Switching to 4.10's TRevsRunner 3rd gen T4Rs 14 11-12-2015 12:01 AM
Did You Think About Switching to 18's? Drak 4th Gen T4Rs 4 08-24-2014 03:21 AM
switching into 4H and 4L Cederbaum 4th Gen T4Rs 4 01-31-2008 12:08 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
