Old 01-19-2021, 11:30 PM #1
nvbirdman nvbirdman is offline
nvbirdman is on a distinguished road
Transmission fluid?
'18 4runner, I was under the hood and checked the oil level just for fun. It was great. Might as well check the transmission fluid level too.
No dipstick. Looked in the owner's manual and there was nothing on checking the trans fluid level.
Do you go under the truck and pull a plug and stick your finger in like a standard trans?
Not concerned about it, just got me to wondering.
nvbirdman is offline   Reply With QuoteReply With Quote
Old 01-19-2021, 11:46 PM #2
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep has a spectacular aura about wcjeep has a spectacular aura about wcjeep has a spectacular aura about
wcjeep's Avatar
Haven't looked on my 18'.
On my daughters 2007 Jeep Grand Cherokee I had to buy a standalone dipstick that's a temporary use only.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 01-20-2021, 01:03 AM #3
spartacus's Avatar
spartacus's Avatar
No dipstick. Just paraphrasing so here it goes, you will need to a vacuum canister to apply 3 to 5lbs of hg to the fill plug buy a Toyota oem ATF tool take the drain plug out hookup a obd to make sure atf temp is between 105* to 113* degrees and then check for fluid if it's flowing out the gizmo it's over filled, if it's barely dripping you are good.If it's not flowing at all then you'll have to put the plug back disconnect the vacuum hose to the fill port, pump fluid in it. Hook up the vacuum back bring the temp backup to spec and check the Toyota oem gizmo for fluid barely dripping. And you are good to go.
fluid , level , oil , trans , transmission
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission flush vs. transmission fluid drain and refill... Bad_Influence 5th gen T4Rs 18 03-08-2022 12:03 AM
Transmission Fluid (tricky situation) (muddy fluid) hairpin 3rd gen T4Rs 16 10-31-2020 09:25 PM
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
