Old 02-12-2021, 08:36 PM #16
Burt Burt is offline
Burt is on a distinguished road
Here in CO, 85 is the regular grade with up to 10% ethanol.
Been using it in my '08 V6 for 11 years with no issues, even towing and jumping over 13k mountain passed. I put high priority on quality fluids.
Burt
2008 SR5 V6 4WD
1984 1/2 GT350 Mustang
2019 F250 SuperDuty
Burt is offline   Reply With QuoteReply With Quote
Old 02-12-2021, 09:39 PM #17
sledride sledride is offline
sledride is on a distinguished road
Definitely not.
sledride is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 01:23 PM #18
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
I also used the 85 octane trash CO fuel in many of my trucks for years with no ill effect.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 12:33 PM #19
Eltigreblanco Eltigreblanco is offline
Eltigreblanco is on a distinguished road
I use premium while towing
Eltigreblanco is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:43 AM #20
mnofpeace's Avatar
mnofpeace mnofpeace is offline
Real Name: Patrick
mnofpeace has a spectacular aura about mnofpeace has a spectacular aura about
mnofpeace's Avatar
Real Name: Patrick
no real benefits...
however
being an old racer, i know that higher octane gas runs/burns better/hotter, and that gives any engine a tad more power. researching it in the 4runners (5th Gens), i know using regular gives us about 270hp...but using 93 octane gives us roughly 300hp.
so for me, i only uses high octane gas when im going to be towing something, like my motorcycle trailer.
but under any other normal use...all gas octane levels are mandated by regulations to have the same chemical and cleaning benefits.
and as has been said...our truck engines are built to use 87 octane gas...and that is high-priced enough as it is...
Patrick L
Ft. Washington, Md.
2014 SR5 w/ 3rd row
My TRD-Pro-Lite
mnofpeace is offline   Reply With QuoteReply With Quote
Old 04-06-2021, 09:59 AM #21
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
Yeah, as a mechanic & engine builder, your 270hp on 87 octane isn't going to magically produce 300hp going to 93 octane. The higher octane helps prevent detonation, allowing higher compression ratios and more aggressive valve timing... which is where you get your power. You're going to see a negligible improvement in your truck engine.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 04:39 PM #22
baldrik78's Avatar
baldrik78 baldrik78 is offline
baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light baldrik78 is a glorious beacon of light
baldrik78's Avatar
The original 1GR-FE was designed to run on 91+ octane fuel. At 87 octane, the current engine is rated for 270 hp; at 91+ octane, the engine is rated for 285 hp. When you run lower octane, the ECU retards the timing and when you run higher octane it advances the timing.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
baldrik78 is offline   Reply With QuoteReply With Quote
Old 04-10-2021, 12:06 PM #23
Jernik's Avatar
Jernik Jernik is offline
Real Name: Jeremy
Jernik is a jewel in the rough Jernik is a jewel in the rough Jernik is a jewel in the rough
Jernik's Avatar
Real Name: Jeremy
Maybe placebo, maybe not... ours seems to run a little smoother and act a bit "peppier" on 89 vs 87. I didn't notice any further benefit when trying 91, so have stuck with running 89.
Try different octanes out. It you notice one seems to make your specific truck happier stick with it. Otherwise you can just go back to 87. Overall cash investment for this experiment is pretty low.
Toyota noob
Jernik is offline   Reply With QuoteReply With Quote
Old 04-17-2021, 02:49 PM #24
Twuntish Twuntish is offline
Twuntish is on a distinguished road
Split the difference and go mid grade
Twuntish is offline   Reply With QuoteReply With Quote
Old 04-21-2021, 03:42 AM #25
newt0n newt0n is offline
newt0n is on a distinguished road
I'd say no, premium fuel is only meant for engines designed for it.npretty sure the 4Runner is designed for standard fuel.
newt0n is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 12:34 AM #26
SDsc0rch's Avatar
SDsc0rch SDsc0rch is offline
SDsc0rch is on a distinguished road
SDsc0rch's Avatar
regular
SDsc0rch is offline   Reply With QuoteReply With Quote
Old 04-30-2021, 10:10 AM #27
chowd3r chowd3r is offline
Real Name: Jay
chowd3r is on a distinguished road
Real Name: Jay
Regular all day.
chowd3r is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 10:21 AM #28
Bchavers Bchavers is offline
Bchavers is on a distinguished road
Thank you all for your input.
Bchavers is offline   Reply With QuoteReply With Quote
colored , fuel , odd , premium , shape
Premium fuel ? rodsrunner 4th Gen T4Rs 2 07-29-2019 02:55 PM
FJ Cruiser Premium Fuel vs. 4Runner Premuim Fuel truckmike26 Engines / Suspension / Wheels / Tires / Audio / Accessories 23 07-05-2011 09:27 PM
Using Premium Fuel ?? Sandpiper 4th Gen T4Rs 7 03-28-2011 07:04 PM
Premium Fuel (91/93 Oct) in your V8? JG1911 4th Gen T4Rs 5 08-29-2010 11:41 PM
V6 and premium fuel CJ3Flyr 4th Gen T4Rs 18 01-19-2008 07:46 PM
