Originally Posted by CajunMikeR
Yeah, as a mechanic & engine builder, your 270hp on 87 octane isn't going to magically produce 300hp going to 93 octane. The higher octane helps prevent detonation, allowing higher compression ratios and more aggressive valve timing... which is where you get your power. You're going to see a negligible improvement in your truck engine.
The original 1GR-FE was designed to run on 91+ octane fuel. At 87 octane, the current engine is rated for 270 hp; at 91+ octane, the engine is rated for 285 hp. When you run lower octane, the ECU retards the timing and when you run higher octane it advances the timing.
2017 TRD ORP KDSS IG
Dobinsons IMS w/ 314/325 Coils - JBA UCAs - Durobumps - Firestone 4108
DRKDSS Disconnect Switch - Treaty Oak KDSS Spacers - Eimkeith PCK
SSO Roof Rack - SSO Sliders - SSO Slimline - Smittybilt X20 10k - RCI Skids
TRD Pro Wheels - Spidertrax Spacers - Mickey Thompson Baja Boss A/T 255/85 R17
