02-01-2021, 10:48 AM
Premium fuel ya or na
I have a 2001 toyota 4runner. With 275000 plus miles. Is there any real benefit to using premium fuel. My engine seems to be in great shape no odd colored exhaust.
02-01-2021, 10:53 AM
No.
The engine was designed for “regular”
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
02-01-2021, 11:01 AM
I had a 2001 as well. Agreed, regular gas is fine - the truck was built for it. BUT, on one long vacation trip (about 6000 miles), I saw that there were places out west selling gasoline without ethanol added. I decided to experiment, since I was watching mpgs out of curiosity due to pulling a trailer. I filled with straight gasoline when I could, and mileage seemed to increase by around 2 mpg. It wasn't premium, just no ethanol. A bit more expensive, too, so there was no economic gain.
02-01-2021, 11:22 AM
You'll be fine with 87.
02-04-2021, 07:46 PM
na just do regular
02-04-2021, 11:50 PM
Higher octane (effectively) burns slower, so you loose efficiency. think of it like this. since it burns slower, some of the available heat isn't totally taken advantage of or used, and escapes out the exhaust ports prior to burning. You need the extra compression and timing to take advantage of the premium fuel. So its money wasted out the tail pipe. Not totally scientifically correct, but close enough to get the point across. At higher density altitudes it gets worse.
02-05-2021, 12:23 AM
Real Name: MURDERED TRD
You’d be wasting money putting premium in that old rig.
02-07-2021, 06:57 AM
Real Name: Steven
Real Name: Steven
I see positive results from burning premium. Runs better and the mileage is improved. To each their own.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
02-07-2021, 10:32 AM
Depending on where you were in the West, altitude could also attribute to better gas mileage. I lived at about 4600' in AZ and got about 2 MPG better on average than I do now that I am in lower elevations--same vehicle.
02-07-2021, 10:53 AM
That's interesting. I wouldn't expect that, considering that the normal octane out there is (was) 85.5. But honestly, I didn't pay attention to any mpg/altitude connection. Maybe I was seeing what you're describing instead.
02-07-2021, 12:05 PM
Real Name: Mark
Real Name: Mark
Nay for premium
Have never noticed a difference with premium fuel ethanol or non in 4Runner.
My Audi V8 yes makes a difference premium real gas all it ever gets.
02-08-2021, 11:40 AM
Real Name: Kevin
Real Name: Kevin
I traveled from CO to TX in my FJ, and lost 4-5mpg. MAn, I was glad to get back to 7000'!
Bullets, blades, bourbon, and buoyancy. No necessarily in that order.
'21 TRD OR, Nautical Blue, 3" Toytec lift, 285/70/R17 Cooper Discoverer AT3, Toytec rock sliders, blacked out badges, LED high beams, Sprint Booster.
02-08-2021, 12:28 PM
Less power better milage at high altitudes.
02-08-2021, 02:49 PM
unclear if premium will help - as you can see from previous comments.
But one of the things that is generally recommended is using "Top Tier" gasoline brands. They detergents and other additives that some research has shown to help keep the engine clean and running well. - based on AAA, consumer reports, etc
Homepage
02-08-2021, 09:36 PM
MyFJ had the 4.0 and I went back and forth with premium and regular and never noticed a difference either way. My fourth gen has a V8 and I run regular. Just run regular unless your OCD won't let you put regular in there. Lol
2005 Limited 4X4 V8 36,000 original miles. 265/70/17 BFG KO2s, Front: Bilstein 5100s set to 3rd perch with stock springs. Rear: OME 895E springs and driver OME trim packer driver side with 5100 shocks. 2" overall lift.
