Old 03-28-2021, 09:50 AM #1
Charlievee's Avatar
Charlievee Charlievee is offline
Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all Charlievee is a name known to all
Charlievee's Avatar
Frame prep for bolt on sliders?
I will be adding bolt on sliders and was curious if there is concern for frame damage due to rust. Is it more likely for rust to form where the slider mounts to the frame? sliders will.be coated in POR15, should the frame be done at the mounting/metal on metal contact points also?
2018 TRD Off Road Premium. Eibach Pro, JBA, Toyo's, TRD cai.
Charlievee is offline   Reply With QuoteReply With Quote
Old 03-28-2021, 02:26 PM #2
mr.walleye mr.walleye is offline
mr.walleye will become famous soon enough
I just gave my frame several coats of black paint (and when I say several, I mean 8 and I let it dry in between coats) where the sliders were going to cover up the frame and a dab of antiseize on each bolt before bolting it up, cleaned up all the other surface rust on the frame while I was under there. make sure to plug the bolts holes up before you paint the frame or you will need to clean the paint out because the bolts wont go.. so I hear
mr.walleye is offline   Reply With QuoteReply With Quote
Old 04-01-2021, 08:14 PM #3
batex batex is offline
batex is on a distinguished road
I sprayed some marine corrosion preventative spray on the frame rails and sliders before I bolted them on. Don’t know if that was a good idea, but I assume it doesn’t hurt. The spray was a relatively thick, heavy, tacky film for protecting metals in marine environments. Hope it works.!
batex is offline   Reply With QuoteReply With Quote
Old 04-09-2021, 11:41 AM #4
larrylegend larrylegend is offline
larrylegend is on a distinguished road
I applied a healthy coat of automotive grease to the frame/back of the mounting plate for my sliders. The fitment of the plate to the frame wasn't tight enough to prevent water/salt from entering it, so I figured I needed something to keep it out. Seems to have done a pretty good job so far. I will be removing my sliders soon to have them recoated so I guess I'll see how it performed then.
1999 - Ltd. - Deckplate, 265/75/16 Goodyear Duratracs, Removed Running boards, hurculined entire interior, more to come...
2015 Trail Premium - S.S. Sliders...
larrylegend is offline   Reply With QuoteReply With Quote
Old 06-26-2021, 07:10 PM #5
danktex danktex is offline
danktex is on a distinguished road
I sprayed Fluid Film on the frame and sliders
danktex is offline   Reply With QuoteReply With Quote
Old 06-26-2021, 07:25 PM #6
CajunMikeR's Avatar
CajunMikeR CajunMikeR is offline
CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice CajunMikeR is just really nice
CajunMikeR's Avatar
I cleaned the frame really well at the contact surfaces, applied some rust preventative, then used antiseize on all bolts. Nothing else really needs to be done.
2019 MGM TRD ORP
Dobinsons IMS 3in lift, FN f(x) Pros 17x8in 0 offset, 285/70 C load Nitto Ridge Grapplers, and all sorts of other fun stuff
shootn4runner on IG
CajunMikeR is offline   Reply With QuoteReply With Quote
Old 06-29-2021, 04:38 PM #7
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
I pulled my sliders off after 6 years to blast and repaint about a year ago. There was very little visible damage underneath and no meaningful additional rust as compared to the rest of the frame rails. I just cleaned the frame before I installed.
If anything I would consider using squares of clear-bra to protect the frame rail. But I don't think it's necessary.
Old 06-29-2021, 05:52 PM #8
Deuxdiesel Deuxdiesel is offline
Deuxdiesel has a spectacular aura about Deuxdiesel has a spectacular aura about
Fluid Film, Amsoil HDMP or something like that would be best, plus it can easily be reapplied. POR15 doesn't work very well over clean, painted metal.
Deuxdiesel is offline   Reply With QuoteReply With Quote
bolt , frame , points , rust , sliders
Frame bolt specs Narkhelek 5th gen T4Rs 4 05-28-2020 01:37 AM
Custom made bolt on rock sliders (no frame drilling) fourfive 3rd gen T4Rs 18 04-04-2020 12:57 PM
Stripped Bumper/ Frame Bolt xcmountain80 3rd gen T4Rs 4 03-27-2017 04:47 PM
Frame Rust? Get Klean Strip Prep and Etch at Home Depot! Benski 3rd gen T4Rs 17 05-02-2015 03:13 PM
Rear frame bolt pitch Javelin 4th Gen T4Rs 2 06-26-2012 04:57 PM
