Old 04-02-2021, 03:09 PM #1
hanks4runner hanks4runner is offline
hanks4runner is on a distinguished road
Help Solve Electrical Gremlin in '98 T4R
My '98 T4R 3.4V6, Auto 4WD developed an electrical problem, requiring that I remove the Tail Relay in order to drive it (during daylight hours only!).
With the Tail Relay in, weird intermittent things happen, not only do the parking lights stay on when turned off, but sometimes the starter motor stays running after the engine has started and when engine is turned off, the starter keeps cranking the engine until the battery is disconnected. Also, with the Tail Relay in, one time the engine started and the starter motor kept running until I turned the light switch on, and the starter motor immediately cut out, and when I turned the lights back off, the engine shut off immediately, even thought the ignition switch remained on. I substituted another Toyota relay into the Tail Relay circuit, same things happen. Has this happened to anyone here? It still runs great except for the electrical problem, without the Tail Relay plugged in, it runs normally, head lights, brake lights and turn signals work, but plug that Tail Relay back in and it does some strange things! I've taken it from 75k to over 250k and this is the first problem I've had with it. Does this sound like a grounding problem or maybe a bad light switch or ignition switch? Any comments are appreciated!
hanks4runner is offline   Reply With QuoteReply With Quote
Old 04-02-2021, 03:46 PM #2
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
I don't have an answer but here is my advice because you say "any" is welcome lol.
I'm a licensed electrical contractor and my company specializes in commercial energy efficiency projects...im NOT a master electrician....that being said, we encounter lots of electrical gremlins when retrofitting old buildings and upgrading theatrical lighting systems.....
as you stated replacing the ground is a good place to start. Then its simply a process of elimination. you probably already know this, but you need someone to push you into diving in and committing. Take one switch or item out of the equation, and check to see if there is an impact. If that does not work, put it back and try another. So many times my guys have said that the problem was not X, and when I make them test it, that turns out to be the problem.
anyways, that is my .02
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 04-03-2021, 07:33 AM #3
Thanks for your reply, I do need motivation to work on it..I bought a new Rav4 XLE after it acted up, but I can't let go of the 4Runner!
engine , problem , relay , switch , tail
electrical gremlin 3bears 3rd gen T4Rs 5 04-25-2018 11:59 AM
Rain and electrical gremlin - H E L P rckeat 3rd gen T4Rs 11 11-08-2012 12:49 PM
99 3.4 Auto...Electrical Gremlin dhost78 3rd gen T4Rs 9 06-20-2011 04:53 PM
Electrical Gremlin Kport 5th gen T4Rs 2 11-11-2010 10:39 PM
electrical gremlin or normal? fileechino 4th Gen T4Rs 3 09-24-2009 11:16 PM
