Old 06-29-2021, 05:20 PM #1
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
PS pump shaft groove: worn or factory?
I pulled the power steering pump out of my gs400 earlier to rebuild it and replace the alternator today. It turned out to already have a "remanufactured" sticker on it. When I pulled the shaft there was a groove right around where the seal would make contact with it, jndise the housing, behind the bearing, and the bearing had fluid around it and grease on the outside, which seems likely to have been displaced by fluid.
The groove feels almost sharp, not really worn, but can't imagine why there would be a groove machined there. Anyone seen this on a Toyota or Lexus pump before? Is it a defect? I've only rebuilt one pump before but don't remember seeing anything like this on it.
Bearing also has a significant dent in the backside of the care, seems like it might've been a careless rebuild. Although they did use a Japanese-made NTN bearing at least.
Groove worn into power steering pump shaft
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
bearing , fluid , groove , pump , rebuild
Mysterious noises - worn steering pump? eurasiaoverland 3rd gen T4Rs 15 09-03-2019 05:26 PM
Drive shaft/Prop shaft question (Picture Incl.) rinkman07 4th Gen T4Rs 4 03-31-2014 09:49 PM
Power Steering Pump Shaft Seal peebee 3rd gen T4Rs 12 12-29-2013 12:27 AM
Icon coil-over odd groove/thread marks soundstudio315 Engines / Suspension / Wheels / Tires / Audio / Accessories 14 09-23-2012 11:49 AM
Manually activivating factory air ride pump? 2UZ-FE 4th Gen T4Rs 2 09-30-2010 03:59 PM
