Old 07-03-2021, 07:52 AM #16
MIKE969 MIKE969 is offline
MIKE969 will become famous soon enough
Unless you want a special PRO color or money is no object, get the TRD OFF ROAD. I’d go for premium to get softex and smart key system (2020+). 2021s have LED headlights and fog lights which are FAR superior to the halogens of the 2020 and previous model years.
Here’s the breakdown of the trims:
Limited: not ideal for anything other than dirt roads as bumpers and side skirts are lower to the ground. Quite capable, just more susceptible to trail damage.
SR5/2021 Trail Edition: capable off road but does not have a rear locker or crawl control/Multi terrain Select (MTS).
Trail (2010-2016), TRD off road (2017-2021) and Venture (2020-2021): Has crawl, MTS and most importantly a rear locker. As others said, it shouldn’t be required 99% of the time for the type of off roading you described but if you do need it, it can be the difference between continuing and turning back. KDSS is available and is a good option if you don’t plan to lift more than 2”.
PRO: same features as off road, but with upgraded shocks/springs/wheels/tires out of the box. Special exclusive Colors. Holds its value best, but most expensive to purchase by far especially these days.
2021 TRDORP/KDSS
OEM Pro Grille, Fifteen52 Turbomac HD Graphite (17x8.5 ET 0), Falken Wildpeak AT3W 265/70 SL.
MIKE969 is offline   Reply With QuoteReply With Quote
Old 07-04-2021, 06:39 PM #17
slowdawg84's Avatar
slowdawg84 slowdawg84 is offline
slowdawg84 is on a distinguished road
slowdawg84's Avatar
Originally Posted by Apogee.TRD View Post
In my opinion, the only reason to get a Pro is if you really wanted one of the Pro only colors.
I would have been fine with an SR5, but I wanted the piece of mind of having a manual shift transfer case with the Off Road.
Pretty much my exact thoughts that led me to picking up an ORP in March. I personally feel like the Pro and OR are the same aside from color and price.
slowdawg84 is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 11:50 AM #18
MN_Pat's Avatar
MN_Pat MN_Pat is offline
MN_Pat is on a distinguished road
MN_Pat's Avatar
I think there is one scenario in town where the Limited is superior to the others. When you have constant changes in traction from slippery to dry. Letting the vehicle auto-magically decide when to transfer power as opposed to manual shifting in and out, in and out, in and out of 2ed aka rear wheel drive.
Ex. Winter commute to work. Side streets need 4wd, main street maybe, maybe not, freeway needs 2wd, off free way back into 4wd.
If you don't live in snow country, disregard.
2021 ORP with G.Y. UltraTerrains, Bilstein 6112 1.1" & 5100 rear + Eibach coils 1", & ARB Diff Breather, Accessoride remote start.
MN_Pat is offline   Reply With QuoteReply With Quote
Old 07-06-2021, 01:09 PM #19
Drobs Drobs is offline
Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light Drobs is a glorious beacon of light
Originally Posted by Xuberant View Post
Hello!
Was hoping to get some personal advice prior to making a purchase.
If I plan to do more "off road" like off the beaten path but not to the extreme of needing rock crawling features, would the trail edition 4x4 be sufficient enough?
I want the ability to be able to cross streams, rivers, uneven terrain(not large rocks/boulders) etc during my camping trips. There is about a 15-20k difference in price and from what I read, it seems the trail edition 4x4 has everything I need but seeing as I am new to 4runners, would really appreciate first hand experience from the 4runner family.
Thank you!
A 4x4 Off Road, Off Road Premium, or Venture would be my recommendation. I'm off road almost every weekend and use my locking rear differential all the time.
The current Trail model is a SR5, which doesn't have the locking rear differential.
You really want a locker for water crossings as there is the potential for hidden obstacles under the water. The rear locker allows me to slowly crawl over obstacles vs using momentum that can break things.
Jump to 15 minutes in this video of mine.
The Greer Family Wrangler Rubicon Takes on Glade Top Trail - YouTube
The Jeep Wrangler Rubicon ahead of me struggles in a rock climb. He has 2 things going against him. 1. He didn't have his lockers turned on. 2. The short wheel base. He made it over, it just wasn't pretty.
I had no problem going slow over that same section with my locking rear differential engaged and my longer wheelbase.
Edited to add. There is a $2k-$3k difference in price between the Trail and the Off Road. Get the Off Road.
Trail Edition or TRD Pro..need advice!-trail-vs-off-road-jpg
2019 OR - LT285/70R17 Yokohama Geolandar MT, SPC UCA's, BMC, Eibach Pro Truck Lift, Warn VR10 Winch, Warn 100022 Winch Bumper, TRD Skid Plate, Cali Raised Light Bar, Shrockworks Sliders and Skids, LFD Ruggadized Cross Bars, Sprint Booster.
Drobs is offline   Reply With QuoteReply With Quote
Old 07-07-2021, 11:44 PM #20
Absolutely true. I live in Canada and wish my TRDORP had the limited’s AWD setup but paired with the crawl/mts and rear locker TRDOR setup.
2021 TRDORP/KDSS
Old 07-09-2021, 09:49 AM #21
BullyHans BullyHans is offline
BullyHans is on a distinguished road
BullyHans is offline   Reply With QuoteReply With Quote
Old 07-11-2021, 04:05 PM #22
Xuberant Xuberant is offline
Xuberant is on a distinguished road
Where can I find a TRD Off Road for 40k starting? All the TRD Offroad in SoCal start at 47k lol
Xuberant is offline   Reply With QuoteReply With Quote
4x4 , advice , edition , trail , trips
Trail Edition hood on Limited Edition. Can it be done? socal4rnr 5th gen T4Rs 6 04-10-2016 02:43 PM
2010 4Runner Trail Edition or 2013 FJ Trail Teams mideastbeast61 5th gen T4Rs 22 11-11-2012 03:31 PM
Advice on purchase of 2008 4Runner Sport Edition calrunner 4th Gen T4Rs 18 10-05-2011 07:27 AM
Advice on purchase of 2008 4Runner Sport Edition calrunner 3rd gen T4Rs 6 10-03-2011 06:13 PM
Need Advice. 2008 4x4 Sport Edition SantaCruzOM 4th Gen T4Rs 10 01-21-2011 10:48 AM
