Old 01-16-2022, 07:52 PM #1
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
Oil change SUCK tool
Another thread made me think of this.
If you change your own oil or any fluid drains (vehicle, not body) you need one of these. I have used this for years....a mityvac fluid extractor. Works on a vac pump. Simply send the tube down the dipstick tube and suck out the oil. Works perfect and yes it gets ALL of the oil out. It has measurements on the tank, and on my merc, 4runner and my gf civic, it gets out as much as the spec calls for. Just changed her oil yesterday. 45 buck vs over 100 for a synthetic change. Of course if you not a DIY person its not worth it, but I like doing it and I know its right. Yes, you still have to get under to do the filter, but you don't have to deal with the plug and a huge mess of catching the fluid and cleaning a drain pan. The mity vac also works in reverse, so you just flip the valve and you can pump out the contents over fence into your neighbors yard.
Oil change SUCK tool-20220116_174300-jpg
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 01-16-2022, 08:20 PM #2
rakrak2 rakrak2 is offline
rakrak2 is on a distinguished road
Have seen someone recommend the PELA brand of vacuum oil changers on a Miata forum in the past. Never tried it myself but this fellow swore by it as a way to lighten the work and minimize the mess.
rakrak2 is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 11:01 PM #3
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Old 01-17-2022, 11:38 PM #4
Flyer Flyer is offline
Flyer will become famous soon enough
This is great! I just ordered one. I see the Merc mechanics use this too. I assume the dealers may. I have a GL450 that uses 9.4 quarts and the 4R uses around 7. This will make it much easier and cleaner.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 01-18-2022, 11:47 AM #5
lewdog998's Avatar
lewdog998's Avatar
Couple things to note in my experience with my merc E550..m278 engine, bi turbo 4.7l v8. I specify because I'm not sure all mercs are like this.
1. The filter was top side so oil changes were extremely easy.
2. The oil dipstick tube was a large diameter, maybe 1/2 to 5/8 inch.
3. When inserting the small tube through the dipstock tube to the bottom of the engine I had a a hard time extracting much oil.
4. I found that on this particular engine, you did not have to get the suction tube down the dipstick tube. Just use the large tube stuck into the top like a cork...the suction will draw 100% of the oil up the dipstick tube. (Open your filler cap)
5. Because the m278 is a dry sump engine you must do it this way. It takes 8.8 quarts (if remember correctly) and it would get every bit out.
So in short, on your gl .....if the suction tube down to the pan does not work, try using the actual dipstick tube as the suction....pm me if you have questions.
Old 01-18-2022, 12:11 PM #6
Thanks! I appreciate that and will try it soon. I appreciate the tips. Just need my filters to come in. Mine also has the 4.7L engine.
Old 01-18-2022, 04:52 PM #7
lewdog998's Avatar
lewdog998's Avatar
The m278 is a great engine. I highly recommend the weistec tune. I did mine when it was almost new and put over 100k on the tune with zero issues. It was a beast and the only thing that ever beat me was a hellcat. It ran dead even with an r8 v10, and would beat any mustang, 392 dodge.....you know how fast your car already is, it could turn it into a real "sleeper". No negative effect on drivability either.
Mercedes Benz AMG M278 ECU Tune E550 S550| Weistec
Oil change SUCK tool-tune-jpg
Old 01-19-2022, 03:46 PM #8
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's freakin' insane AND the fact it's CARB legal. I had no idea that engine could produce that sort of power. I guess I should have as it's a twin-turbo!
326WHP 347TQ
Old 01-19-2022, 04:20 PM #9
lewdog998's Avatar
lewdog998's Avatar
Mercedes used the same engine in a lot of different platforms/chassis and would just change the tuning to fit the trim level or platform. In stock form it rated as low as 362 hp in a GL ....up to 449 hp in an S class. so it was built really robust with things like fractured con rods, dry sump oiling....and huge oil capacity.
Old 01-20-2022, 12:42 PM #10
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
Why did you get the manual pump instead of an powered pump?
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 02:12 PM #11
lewdog998's Avatar
lewdog998's Avatar
didnt know there was a powered unit...But i can not see any need for a powered unit. This unit is vacuum powered, so you do not need to pump it constantly to create suction. you simply pump the pump about 10 times and let it do its thang. you dont even have to buy it dinner afterwards.
Old 01-23-2022, 09:48 AM #12
Industrialwrench Industrialwrench is offline
Industrialwrench is on a distinguished road
I have one of the evacuators that’s in the OP. These things are great. I use it on a daily basis, and they typically last about 1-2 years. The only thing I recommend is you always clean it out when done. I’ve had it push the oil out of the pump chamber and onto my truck bed several times because I bumped the valve body upward while putting it away. Then the thing pressurizes and makes a massive mess.
Industrialwrench is offline   Reply With QuoteReply With Quote
change , fluid , oil , tube , works
3rd Gen stock tool kit and spare tire lowering tool dirteater4 Want to Buy/Trade 1 03-20-2018 01:47 PM
2016 4Runner Oil Filter change with special tool? Tex-Tac 5th gen T4Rs 21 03-11-2018 09:47 PM
DIY: Brake Fluid Change / Bleed Using a Scan Tool m85476585 4th Gen T4Rs 9 04-10-2017 10:49 AM
Timing belt/water pump change tool/parts checklist cj80cruiser 3rd gen T4Rs 11 05-03-2014 10:15 PM
2005 4runner price decreasing??? SUCK! SUCK! SUCK! X5Runner 4th Gen T4Rs 21 02-27-2005 01:26 AM
