Old 08-09-2021, 09:29 PM #1
pak pak is offline
pak is on a distinguished road
pak pak is offline
Trailer lights don't work with headlights on
I have a 2002 4runner, never had a trailer light problem before. I don't tow often, but just got a boat trailer and put new lights and wires on it. I am scratching my head as to why the trailer lights, all of them, work perfectly with the headlights off, but not at all with the headlights on.
I've seen some suggestion that the common (brown) wire might be shorted, but with new wires on the trailer, and rechecking the whole length, I can find no shorts.
Any ideas?
pak is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 10:15 AM #2
Squeaks_&_Leaks Squeaks_&_Leaks is offline
Squeaks_&_Leaks is on a distinguished road
I had a 3rd gen 4runner that had a similar issue. It took me awhile to diagnose.
There is a black (or possibly brown) single wire that is part of the trailer wire harness at the rear of the truck. Mine was supposed to be connected on the passenger side behind the plastic trim panel in the trunk but it was disconnected by the previous owner.
Use a multimeter. Connect one probe to the black wire at the truck's plug and connect the other probe to body ground. See if there's continuity. If no continuity, you may need to replace your ground wire or clean the ground point with a wire brush.
Squeaks_&_Leaks is offline   Reply With QuoteReply With Quote
headlights , lights , trailer , wires , work
Which LED or HID work and don't work in 2010-2013 reflector type headlights RysiuM 5th gen T4Rs 24 12-18-2015 07:37 PM
Brake lights and dash lights not working, just hooked up new trailer plug MichaelAngelo 3rd gen T4Rs 3 02-15-2015 11:30 AM
2007 4runner lights, horn and blinkers work, but hazard will not work rki1966 4th Gen T4Rs 1 09-21-2014 02:08 PM
Plugged my new trailer into 4R and brake lights/turn signals don't work mac0822 4th Gen T4Rs 3 05-23-2011 12:50 PM
