Old 09-17-2021, 04:28 PM #1
notanyoldjoe notanyoldjoe is offline
notanyoldjoe is on a distinguished road
Advice on 285,000 mile 4Runner Sport V8
Hey everyone,
I have a 2005 4Runner Sport V8 with 285,000+ miles. The truck has been great to me and my family, but it is having its list of issues now that are beginning to stack up. Wasn't able to address a lot because of finances, but I am now in a good place to start seriously addressing our transportation needs.
Because of how much it needs, my lack of knowledge, and it's high mileage, I need some advice as to what to do next. The truck needs quite a bit right now:
- New Tires
- Timing Belt Change
- Tune Up
- New Valve Gaskets Needed
- It has an air pump failure that is causing it to not pass SMOG
- Tail Gate continues to seize up and stay locked.
- Needs new Shocks all around
The truck is fully paid off and my thoughts are just to start hammering away at repairs, but I'm not sure if it's time to say goodbye instead. I know that these Toyota's can go the distance, but I'm not sure what that distance is.
What do you guys think?
1.Fix it up or trade it in? This is our family's only vehicle so we need to count on it. Can a new engine be placed in these 4runners to keep them going if this engine went kaput? If so, I would want to keep it, since I'm thinking this would STILL be cheaper than a new one.
2.If I keep what do you recommend to address first? I'm thinking tires.
In any case thanks for all your help. Look forward to hearing your thoughts, learning and being a part of the community.
- Joe
notanyoldjoe is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 04:57 PM #2
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Do you know the history, has it been well maintained up to now? Is there any corrosion underneath?
Any vehicle will need tyres and belts at some point, and likely shocks way before 285,000!
What gaskets do you mean?
A tailgate actuator is £180 over here, and this vehicle was never officially imported here. I expect it is much cheaper in the USA. It's not a design I like, pointless electronics, for no benefit, but it is what it is.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 09-17-2021, 05:12 PM #3
Hey Surfer,
It has been maintained fairly well. Oil change every 5000 miles and no corrosion that I can see. I'm in California so it's pretty temperate weather.
And it's the Valve cover Gaskets. I'll clarify that on the OP if possible.
And yes, I'm thinking that just fixing it up is the best option, but curious to see what others feel.
Thanks!
Old 09-17-2021, 05:34 PM #4
SurferUK's Avatar
SurferUK's Avatar
Originally Posted by notanyoldjoe View Post
Hey Surfer,
Thanks!
A known vehicle is worth more to you than an unknown vehicle (Unless you're buying new of course) if you see what I mean. Has the ATF had regular changes?
I'd be temped to do the overhaul, this forum is very helpful for advice. You might even find someone local who can help you out (Not an option for me!)
Old 09-17-2021, 09:04 PM #5
I don't think it's been changed too often actually. But I want to try to fix this guy up. Unfortunately I'm not getting too much traction on this post. Any ideas on where to start looking for advice.
What do you recommend I attack first?
Old 09-18-2021, 06:21 AM #6
SurferUK's Avatar
SurferUK's Avatar
I would get a price for dealing with the air pump issue first, and also the shocks (As far as I can tell most here recommend ditching the X-REAS system and fitting normal Bilstein shocks, so it might work out cheaper than you think vs OEM Toyota.)
As the rest of your list is basically simple maintenance, it gives you a base price to work from for getting a working legal vehicle.
Have a look on here for ATF flush procedure using the cooling lines. It's simple enough, you just need to be methodical and patient.
It's good news there's no corrosion, that was the biggest killer of vehicles over here - off to the scrappy with perfectly serviceable engines etc. Now it seems to be electronics issues. Have you had any electrical gremlins with your truck?
I don't know your skill level or tools collection, but good quality tools are only going to go up in price now and will last a lifetime.
I couldn't rebuild an engine if my life depended on it, but so far I am finding this truck fairly nice to work on. I've done spark plugs, filters, all oils, ATF and coolant. The guides on this forum have been very helpful!
Old 09-18-2021, 01:58 PM #7
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
You got your list posted in first post, so do the timing belt first, while doing that you can fix the air pump and valve cover gaskets, then tires and suspension, right on down the line. There's no need to rebuild the engine if it's been well maintained it will go 4-500K miles, same with trans. Change fluids regularly and fix as fails the small stuff.
Old 09-18-2021, 06:20 PM #8
Thanks so much Surfer. My skill level is definitely beginner. But I will take your advice on getting great quality tools. Any recommendations on tool brands you like?
Old 09-18-2021, 06:27 PM #9
Hey Rdruss,
Thanks for this. Great to hear that these babies can last so long. Makes me feel like it's worth putting in the work.
I'll get on these fixes this week, although I think I need to take it to a guy, because I am honestly very much a beginner. Unless I can get some help on here but it sounds like a pretty complicated job.
Ill update the progress on a different post.
Old 09-19-2021, 07:30 AM #10
SurferUK's Avatar
SurferUK's Avatar
I expect brands are totally different there, but I like Bahco for cost/quality.
We have Snap-On, but that's overkill for a beginner.
Have a look around here and YouTube at guides and vids to get a feel for it.
Start with an oil change perhaps, once you've done it once you'll wonder why you were so worried!
I would suggest getting a cap for the filter as if it has been done up too tight before, it can be a struggle to get off, no problem for experienced people but for a beginner just get the cap and save yourself a load of aggro
Old 09-19-2021, 10:23 AM #11
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Hey Rdruss,
Have someone with experience do the timing belt, that's not a job for a beginner, make a mistake there and the engine could be toast/shot!!
2004 Limited V8
Old 09-21-2021, 01:00 PM #12
Thanks for your input AuSeeker,
That's my gut feeling as well. I'll start with oil changes ;).
Gonna try to find a good Toyota guy around the Montebello, CA area.
If anyone out there knows of someone let me know.
- Joe
Old 09-21-2021, 01:50 PM #13
SurferUK's Avatar
SurferUK's Avatar
- Joe
Let us know how you get on, even if it's just to say "Everything went better than expected"
Old 09-21-2021, 02:17 PM #14
Flyer Flyer is offline
Flyer will become famous soon enough
That is way too high mileage for me. I'd get something else.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 07:01 AM #15
RichinRidgewood's Avatar
RichinRidgewood RichinRidgewood is offline
RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold RichinRidgewood is a splendid one to behold
You are into it for $1000’s. Start looking for a new one out of state and trade this one in. You would be amazed what dealerships will give on trade ins lately (I’ve heard)
2020 4Runner SR5 Premium 4x4
Barcelona Red, Graphite/Grey
Sunroof
RichinRidgewood is offline   Reply With QuoteReply With Quote
advice , distance , engine , start , truck
Some Advice on 285,000 mile 4Runner Sport V8 notanyoldjoe 4th Gen T4Rs 4 09-19-2021 12:54 PM
Maintenance Advice on a 2008, 107K mile V8 SR5 4Runner RPC 4th Gen T4Rs 7 02-29-2020 01:42 PM
90,000 Mile Service - 08 Sport V6 4WD hojodro 4th Gen T4Rs 9 04-26-2016 01:20 PM
Need Advice: 2006 4runner V8 sport Derrwei 4th Gen T4Rs 12 01-03-2013 12:22 AM
Possibly looking into a 4Runner 2005 Sport, need pricing advice kseto 4th Gen T4Rs 3 10-19-2005 08:32 PM
