Old 10-11-2021, 01:14 PM #16
mscot mscot is offline
mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light mscot is a glorious beacon of light
Originally Posted by Jakeepoo3 View Post
40 mph
^ not even remotely correct.
Build thread
mscot is offline   Reply With QuoteReply With Quote
Old 10-11-2021, 01:47 PM #17
spartacus's Avatar
spartacus's Avatar
Originally Posted by Jetboy View Post
Max speed is not 60mph for driving in 4hi in the 5th gen. The max speed to shift from 2hi to 4hi is 60mph. The limit is because there's a clutch that engages to bring the non-spinning parts up to speed in the transfer case before the gears mesh. So it has a max engagement speed. Over that speed it just tells you to slow down before it'll engage. Max driving speed in 4hi is 113mph in the 5th gen. I believe that is the same for all models. The Limited version shares the same drive train entirely except the transfer case is awd and it lacks the front passenger side intermediate axle shaft disconnect mechanism. And it also shares the same 113mph speed governor I think.
65mph is no problem in 4hi on wet roads. I wouldn't think twice about 80mph cruising in 4hi. I've done it many times.
Good luck.
This is news to me. I believed that the limited awd had a center differential that the part time 4 wheel drive lack. Therefore causing the transfer case to wear out prematurely.
Exclusive to the 4Runner Limited, the full-time 4WD system uses a Torsen® center differential with locking feature and a three-mode, center console-mounted switch. The system uses a 40:60 torque split in most driving situations and alters that in response to slippage. If the front wheels are slipping while the vehicle is turning, the Torsen® differential changes the split to 30:70. If the rear wheels slip while the vehicle is turning, the differential changes to a 53:47 split.
Old 10-11-2021, 11:31 PM #18
Jetboy's Avatar
Jetboy Jetboy is offline
Jetboy's Avatar
Yes the limited has an AWD transfer case. VF4BM I think. Like I said. I don't think that has any bearing on max speed other than to suggest that there's not a constraint from the front axle system. Presumably going north of 100mph is unlikely to involve tight corners where the center differential would come into play.
Old 10-11-2021, 11:43 PM #19
Jetboy's Avatar
Jetboy's Avatar
Originally Posted by 08 Hilux Surf View Post
Thank you for your input/comments. Yes, I agree about the max speed when shifting to 4H from 2H. But I never seem to get a clear answer on the max speed driving on 4H. Furthermore, I get more comments that I shouldn't drive on wet surface. All my other 4WD Toyotas driven in Japan recommended/allowed me to drive 4H on wet, dirt, or snow conditions. Obviously I'm not trying to damage the 4wd on my new TRD OR, but my main purpose of driving in 4H is the "traction" while driving in the rain for "safety purpose". Freeway surface may be smooth, but with rain driving around 60-75mph there are always some slight curves, uneven surface, or small holes, and even possibility of hydroplaning as the amount rain/pour can change constantly... And of course I wouldn't drive 60-75mph in heavy snow either. I get various comments which is a bit confusing but thank you for your comments!
There's really nothing you can do to damage it. The system is robust and can handle being driven in 4x4 on dry pavement all you want at any speed it will go. It'll just be uncomfortable on tight corners where it'll bind up. It's possible it could cause some handling issues as well on curvy roads if you're pushing the limits of available traction. But you won't break anything. It takes a lot more stress and abuse off road.
And you won't overheat the 4x4 components at speed.
IMO - toss it in 4hi whenever you want.
I rarely use it on pavement unless it's snowy or icy. The roads where i live don't tend to be all that slippery when wet - or I don't drive fast enough to find the limits. If I'm in doubt, I'll just pop it in 4hi. But I have driven from Salt lake to Moab Utah and back towing my camper in 4hi the entire way mid summer in 100* temps and dry roads. No issues at all. (I had an unknown at the time problem with my front ARB grinding its internal spider gears unless it was in 4wd, but I was a trail guide at a club event so I just ran in 4hi.)
Old 10-11-2021, 11:57 PM #20
Jetboy's Avatar
Jetboy's Avatar
Originally Posted by Baystate4Runner View Post
Speed gov in 5th Gen models is 118mph and that’s were mine kicks in (speed measured with GPS)
That sounds right. Been a while since I tested it. Tires are 118 speed rating so they'd probably match that with the governor.
Old 11-02-2021, 09:43 AM #21
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
As long as the condition is poor traction like snow, you can drive any speed you wish. You’re not going to be able to drive fast enough safely to test the limits of the four-wheel-drive.
Dry pavement is a little different. Not needed, turn off 4x4.
I’ve done between 60 and 70 mph many many many times during very spirited driving on gravel roads on the BLMwith my 3rd gen.
I’ve done 80mph a million times in my 05 ram towing sled trailers.
The bottom line is you’re not going to hurt anything. I’ve spent more time in four-wheel-drive the last 30 years than most people have ever even thought about. It’s a tool, use it.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 11-09-2021, 06:50 PM #22
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Originally Posted by JK47! View Post
This is good info. Is anyone aware of an actual situation occurring with a Gen5 where driving in H4 improperly has damaged the 4x4 system? Just wondering how much abuse it would take to break something.
Maybe not apples to apples, but ...
Previous to my ‘18 SR5, I had a 2002 Tacoma TRD with 5-speed manual transmission. I bought the truck new. It was equipped with the optional pushbutton 4WD engagement button switch in the transfer case lever; the lever only shifted between HI and LO ranges. At the time, i lived in California’s eastern Sierra Nevada near Bishop in the small town of Big Pine.
Not long after I purchased the truck, I was in Mammoth Lakes, 60 miles from home. The drive home was on paved highways with gentle and long sweeping curves. Speed limits were 65 mph at the time except driving through Bishop. It was a summer day and pavement was dry.
I drove the hour home enjoying the late afternoon scenery at up to 70 mph. The truck drove normally until I made the right turn in Big Pine to drive up the street to my home. That’s when I noticed the crow hop. Looking down I saw that the 4x4 light was lit (I’m color blind in the red spectrum so didn’t notice it since it was daylight). I shifted back into 2WD with no issues.
So obviously, I at some point while in Mammoth Lakes accidentally knocked or pushed in the 4WD button. After that experience, I took more notice of making sure my 4x4 light wasn’t lit while on dry pavement.
Since the area recieves regular snow in the winter, driving US395 the roads often alternate between wet, dry, snow and ice. During heavy snows, snowplows are constantly working to get down to pavement so I always kept the truck in 4WD HI when there was any ice and snow, even with large gaps of simply wet pavement.
In addition, the truck was always in 4WD HI when off the pavement, even on high speed maintained dirt roads. I always had the habit to shift into 4WD regularly to keep mechanisms limber. In those days in southwestern Nevada, Death Valley and the eastern Sierra I used to do a lot of class 3 and light 4 off roading.
I owned the truck until I bought my 4Runner. Instead of trading in the Tacoma, I gave it to my adult son, who still has it. The truck has over 200k on it and never has experienced any issues with the running train.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
4wd , drive , driving , surface , wet
Best driving practice for driving up hill Satter 3rd gen T4Rs 35 02-02-2020 05:35 PM
Driving in 4wd? Schamattack 4th Gen T4Rs 1 01-11-2018 10:26 AM
TJM Xray Driving Light - 220mm QH Driving zooroadbaja For Sale: Non-T4R Items 1 05-16-2013 09:35 PM
Think twice before driving in.... taylz Classic T4Rs 1 04-01-2012 09:55 PM
