Old 01-04-2022, 03:49 PM #1
Cezar Cezar is offline
Cezar is on a distinguished road
Tire reccomendation please
Hi, I have this lift kit installed: PRO-TRUCK LIFT SYSTEM (Stage 1) - TOYOTA 4Runner Base
And my OEM tires are due for replacement. I'm having a kid in february and I have an hour drive on country roads to get to the hospital, so I am thinking it might be a good idea to get fresh rubber on there just in case the weather is bad that day. Preferably something that also does well for off-roading. The OEM tires are mall-crawlers and while they do great on-road, they are completely worthless off-road.
The truck is basically a spare vehicle so treadwear rating is irrelevant and so is on-road ride quality (as long as it's not complete torture). I live out in the country and I have trails out on my property so I would like to get something with more off-road focus.
What size / model tires would you guys suggest for going up in size (but safely within the contraints of my lift) and have better mud / snow capability?
Cezar is offline   Reply With QuoteReply With Quote
Old 01-04-2022, 05:44 PM #2
Oops, meant to post this in 4th gen. please ignore
Old 01-04-2022, 09:04 PM #3
Patski00469 Patski00469 is offline
Patski00469 is on a distinguished road
Tires are hit or miss in terms of quality, some times you just get a bad batch regardless of price. Id recommend something 10 ply tho if you drive alot of dirt roads. I jave duratrac wranglers on my runner they do the job
Patski00469 is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 10:11 AM #4
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
You can’t go wrong with BFG KO2. Great for off-road (except mud). Pretty quiet on highway. Ride comfort is decent. Lasts a long time.
If you want something less off-road-y, then Michelin Defender is a great choice. Very quiet on highway. Great on mileage. Tough enough for mild-mod off-reading.
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 11:47 PM #5
Flyer Flyer is offline
Flyer will become famous soon enough
I like the KO2s a lot- a bit off-road focused but mild off-road to medium off-road minus mud. It does pretty decent on the highway. I do not like them on snow but I also do not like ANY AS or AT on snow except for the DuraTrac (gets noisy though solid tire).
Michelin Defenders and Pirelli Zero AS are good tires that are pavement focused.
Size- I woudl not go any more than 32" or 33" equivalent. 33s should not rub on the inner fenders with that lift but do confirm with the dealer.
2005 V8 4Runner 4X4 SR5, FJ TRD Bilstein Suspension, KO2s
2020 Mercedes GLE450
2014 Wrangler Rubicon, Synergy suspension + 35 MTRs + way too many mods
Flyer is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 12:18 AM #6
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Look into the new Baja Boss. I have the ATZ P3. It is a true hybrid tire plus it has silica, both of which are advantages over the KO2, off and on road, respectively.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 01-10-2022, 12:30 AM #7
ANoob ANoob is offline
ANoob is on a distinguished road
Originally Posted by Thai View Post
Lasts a long time.
That's NOT a good thing about a tire.
ANoob is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 04:32 PM #8
Well, the DuraTrac lasts a short time, relatively speaking. It is a softer compound than the KO2. The KO2 lasts longer but not like it goes 70K or anything close. It has decent grip on and off road, though the DuraTrac has superior grip everywhere...rocks, sand, slush, snow, pavement. I just could not stand the sound of the DT's as they wore and the treadblock gaps increased. I replaced them at around 15K when they started to howl a bit. The KO2s are maybe 80% of the DT, much quieter, last longer, and I use them till the winter snow arrives. Then I put on Blizzaks or Nokians since I love driving on snowy mountain roads and do some snow-related sports.
Old 01-11-2022, 05:31 PM #9
comtn4x4's Avatar
comtn4x4 comtn4x4 is offline
comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold comtn4x4 is a splendid one to behold
comtn4x4's Avatar
I agree the Baja Boss looks like a great alternative and 3PMSF rated up to 35" to boot. But OMG heavy AF. 64# for a 285/70. I am strongly considering these in 35" next go around
comtn4x4 is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 04:19 PM #10
Polyguy79's Avatar
Polyguy79 Polyguy79 is offline
Polyguy79 is on a distinguished road
Polyguy79's Avatar
Toyo Open Country AT III’s all day long and twice on Sunday!
Polyguy79 is offline   Reply With QuoteReply With Quote
Old 01-15-2022, 07:03 PM #11
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
OC AT3 all the way
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 03:55 PM #12
ghabe ghabe is offline
ghabe is on a distinguished road
What is considered “bad weather” where you’re located? Around here, bad weather requires dedicated snow tires… I run NOKIAN HAKKAPELIITTA LT3 and I wouldn’t run any lesser tires in the winter. Since you mention off-roading, I’m assuming you’re looking for A/T tires. Any of the 3PMSF rated tires from the major brand should serve you well if you have to deal with occasional snow: BFG KO2, General Grabber ATX, Cooper Discoverer Rugged Trek, Falken Wildpeak AT3…
ghabe is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 03:42 PM #13
MN_Pat's Avatar
MN_Pat MN_Pat is offline
MN_Pat is on a distinguished road
MN_Pat's Avatar
Originally Posted by ghabe View Post
What is considered “bad weather” where you’re located? I’m assuming you’re looking for A/T tires. Any of the 3PMSF rated tires from the major brand should serve you well if you have to deal with occasional snow: BFG KO2, General Grabber ATX, Cooper Discoverer Rugged Trek, Falken Wildpeak AT3…
Tire choice: Like @ghabe said, Any reputable AT tire will work well. Yes as pointed out the KO2 is not as good in snow as the Duratrac or a dedicated snow tire. How much is snow a factor in Kentucky???
Tire size: stay stock or the most popular next size with 285s. No wrong choice here. Watch for load rating changes from 265 to 285. No need for "e" rated for mild off roading.
I'm 10,000 miles into a set of GoodYear Ultra-terrains(265 sl rated). They are rapidly becoming my favorite tire ever. Quieter than the Duratracs, more aggressive than other AT options, and really good in snow. Snow and road noise were the most important factors for me. Ymmv if you don't live where winter is all consuming months on end.
2021 ORP with G.Y. UltraTerrains, Bilstein 6112 1.1" & 5100 rear + Eibach coils 1", & ARB Diff Breather, Accessoride remote start.
MN_Pat is offline   Reply With QuoteReply With Quote
lift , oem , on-road , size , tires
rear cargo strap reccomendation amalik 3rd gen T4Rs 1 05-23-2016 01:18 AM
paint shop reccomendation fenfen Mexico 0 03-06-2016 01:00 AM
Tires Reccomendation? Hankook OR Falken? benzgt 3rd gen T4Rs 15 08-29-2013 01:20 PM
Pioneer/Alpine unit reccomendation Jeff4runner Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-01-2011 11:43 PM
Remote Starter Reccomendation? drewjohnson 3rd gen T4Rs 15 11-10-2008 08:56 PM
