Old 05-31-2022, 09:06 PM #1
supawabb supawabb is offline
supawabb is on a distinguished road
Trailer light connection...
I am installing trailer lights onto a trailer which currently does not have any lights on it.
Each light has a brake, turn signal and back up light with 5 wires. Wires are:
Yellow - Turn signal
Red - Brake
White - Back up (reverse)
Black - Ground
Green - To tail light (power?)
The 4runner has two plug options, the 4 pin and the 7 pin.
Anyone have any idea how to wire this? Draw a diagram and post it?
Appreciate any help!
2017 Limited Mag Grey
supawabb is offline   Reply With QuoteReply With Quote
Old 05-31-2022, 11:29 PM #2
4Reak Show's Avatar
4Reak Show's Avatar
Most trailers combine the turn and brake into a single, multi-use filament. So a standard 7-way is
12v battery power
Ground
Trailer electric brake control
Left turn/brake
Right turn/brake
Reverse
Tail/running lights
And a 4-way:
Ground
Tail/running lights
Left turn/brake
Right turn/brake
A Toyota is how you describe your trailer: a seperate turn signal bulb from the brake bulb. And when wiring up a trailer light connector to a Toyota that doesn’t have it from factory, there’s a special box you buy to convert the different bulbs for turn signal and brakes into a single output. So what’s funny is that you would need like a reverse style one of those magic boxes. Not sure if that exists.
I would forego all that and just combine the brake and turn trigger wires on the trailer. That’s the simplest way to do it. The pins on the 4Runner’s 4-way and 7-way both use the turn signals as the trailer’s brake lights. So even if you ran your own seperate trigger wire for brake lights off the brake pedal let’s say, (which is ridiculous) the trailer would still illuminate its brake lights AND turn signals anyway.
Old 06-01-2022, 01:37 PM #3
Ascole Ascole is offline
Ascole will become famous soon enough
Wire color is a little different on your lights but you should get the general idea with included diagram. Unless you have trailer brakes, you’ll use the 4 pin
Ascole is offline   Reply With QuoteReply With Quote
back , light , pin , trailer , wires
Fog light connection bad tombob55 4th Gen T4Rs 6 12-29-2016 11:29 PM
2013 Trail Edition Trailer Brake Jumper Harness Wire Connection gerrik 5th gen T4Rs 1 08-28-2015 07:41 PM
Tailight and trailer connection questions ksroqclimber 3rd gen T4Rs 19 12-01-2010 03:23 PM
Connection for trailer lights BretSuAz 4th Gen T4Rs 8 03-17-2009 12:38 AM
Trailer connection standard on 4Runners? RamThis 4th Gen T4Rs 7 08-22-2007 09:23 AM
