Old 06-21-2022, 12:56 PM #16
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Originally Posted by McLoven1t562 View Post
It's like spending a little extra on Toyota Red Coolant & Distilled Water......WORTH IT!!! lol
Yep!
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 06-21-2022, 02:06 PM #17
OverByte OverByte is offline
OverByte is on a distinguished road
Check the FSM (Factory service manual) and see what the ATF type is that they recommend and make sure any after market brand you pick uses only the manufactures recommendation. I have a 2002 Toyota 4 runner and I’m currently using Mobile 1 full synthetic ATF on a rebuilt transmission.
OverByte is offline   Reply With QuoteReply With Quote
Old 06-21-2022, 05:25 PM #18
McLoven1t562 McLoven1t562 is offline
McLoven1t562 is on a distinguished road
just called my local dealer in Huntington Beach, CA and it's only $10 bucks for the Dextron 3 it calls for. For something like a trans fluid exchange, $20-$30 is super reasonable lol
I mean you're talking probably less then what most of us spend on High Mileage Oil & Filter and you're definitely not swapping trans fluid every what? 5,000 miles?
McLoven1t562 is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 12:04 AM #19
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I mean, I guess? As long as you're not using generic green coolant, most Asian formula stuff should easily cover Toyota's LLC (Red) specification.
Please tell me you have a 3rd gen and you're not putting Dex III in a WS transmission.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 10:13 AM #20
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
The red isn't even super long life is it?
Come on people it's a Toyota not a Bugatti. Mine has Motul in the AT, Febi Bilstein pink G12+ and deionised water in the radiator, and Millers Oils Trident Professional C3 5W-30 Fully Synthetic Engine Oil in the sump...and it purrs. It MIGHT shave a day or two off of it's ultimate lifespan, who knows. It's still better than the 'normal' approach of leaving factory fluids in for 20 years, anyway.
I guarantee there are trucks out there mis-filled with wholly unsuitable fluids by your 'Nearest qualified service department', still in running order. Hell, my own garage put green coolant in my old Suzuki Grand Vitara when I CBA to do a coolant change myself one time. It's only because I checked it and had specified silicate free pink I noticed...most people wouldn't.
I've never had to scrap or fix any vehicle because of any issue that could be caused by fluids, and the only OEM fluid I have ever bought was dual pump fluid for a CR-V, which had been filled with normal diff oil by the previous owner! In the end, that went due to a knock sensor issue with the rear diff still working.
In these times where every dollar/pound take your pick matters, it's important people maximise value.
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
Old 06-22-2022, 01:47 PM #21
yea I get that, idk the red doesn't cost much more then any others I see and I have a dealership real close to me lol
My bad, it's Dex 2. Looked it up on my companies Mitchell system and that's what it says for AT Fluid and yes it's a 3rd gen...96 SR5 4x4
$12/qt , factory , fluid , transmission , valvoline
Engine Oil, Transmission Fluid, Rear Diff Fluid, Recommendations? EveningCommuter 3rd gen T4Rs 42 12-13-2019 05:56 PM
Fluid Choice, Illegal Warranty Denial and Magnuson–Moss Act XswampX General Discussions 28 11-07-2016 10:38 AM
Differential and transfer case fluid choice: rgcary Maintenance/Detailing 2 02-19-2010 08:57 PM
Transmission choice toytrukn78 4th Gen T4Rs 18 10-28-2008 08:48 PM
Brake fluid, transmission fluid, and rear differential fluid NViejeP 4th Gen T4Rs 12 03-31-2007 03:43 PM
