Originally Posted by BlackWorksInc
I mean, I guess? As long as you're not using generic green coolant, most Asian formula stuff should easily cover Toyota's LLC (Red) specification.
Please tell me you have a 3rd gen and you're not putting Dex III in a WS transmission.
The red isn't even super long life is it?
Come on people it's a Toyota not a Bugatti. Mine has Motul in the AT, Febi Bilstein pink G12+ and deionised water in the radiator, and Millers Oils Trident Professional C3 5W-30 Fully Synthetic Engine Oil in the sump...and it purrs. It
MIGHT shave a day or two off of it's ultimate lifespan, who knows. It's still better than the 'normal' approach of leaving factory fluids in for 20 years, anyway.
I guarantee there are trucks out there mis-filled with wholly unsuitable fluids by your 'Nearest qualified service department', still in running order. Hell, my own garage put green coolant in my old Suzuki Grand Vitara when I CBA to do a coolant change myself one time. It's only because I checked it and had specified silicate free pink I noticed...most people wouldn't.
I've never had to scrap or fix any vehicle because of any issue that could be caused by fluids, and the only OEM fluid I have ever bought was dual pump fluid for a CR-V, which had been filled with normal diff oil by the previous owner! In the end, that went due to a knock sensor issue with the rear diff still working.
In these times where every dollar/pound take your pick matters, it's important people maximise value.
