Originally Posted by ArthurKotb
It could be a weak battery or it could be your starter is dragging because of a poor connection on the battery cables/starter connector. Interior lights are not a good indicator of battery strength. Neither is a volt meter but it could give you some indication. The starter draws a lot of amps when you're cranking so a good tester would be a battery load tester.
Check your battery terminals to be sure they're nice and clean, no corrosion. Also check the connection at the starter for corrosion. I would get the battery tested next; local parts store cab help. If you take the starter off they could test that too.
Yup...bad battery. Was only cranking at 400 amps and not the 750. Thank you.
