Originally Posted by jrmyrnsm
Timing belt was done about 10k ago, would it run if the belt were broken?
No it wouldn't run if the belt was broken...but it could run if it slipped a tooth on a timing gear.
That being said, the best I could hear from the video IMHO it sounds too good in the beginning to be even a slipped tooth.
It could be starving for fuel, bad coils or a failing computer causing it to start to misfire.
Unfortunately you're going to have to do some trouble shooting/diagnostics to find out what is causing the issue, hopefully it's not terminal.
