Old 12-03-2022, 11:02 PM #16
fourwd1's Avatar
fourwd1 fourwd1 is offline
Moderator
Real Name: The Chosen One
fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough fourwd1 is a jewel in the rough
Moderator
fourwd1's Avatar
You've made a few valid points and explained some things more in depth than I went into. Back in the '80s it was cheaper to buy a new piston and rebuild kit from Toyota than buy a reman caliper, so I've rebuilt a lot of them. I understand what you say about the silicon grease and all that. Been there done that.
But moisture contaminated brake fluid is still a major contributor to caliper pistons freezing up. The nature of brake parts constantly cycling from low temps to very high temps thru normal use is a major factor.
Not everyone here lives in the very dry west coast where this may be less of a problem.
'89 4Runner SR5 - stock
fourwd1 is offline   Reply With QuoteReply With Quote
Old 12-03-2022, 11:20 PM #17
lbhsbz lbhsbz is offline
lbhsbz is on a distinguished road
I've torn down tens of thousands of caliper cores from all over the world and the only ones where I've every seen rust on the wet side of the seal were those that had been sitting outside in a pile of junk getting rained on for years.
While brake fluid is hygroscopic, the whole point of that is so that water never exists in high enough concentrations in the system to cause corrosion. If it didn't mix with water, we'd have little droplets in places causing corrosion.
lbhsbz is offline   Reply With QuoteReply With Quote
caliper , failed , front , needed , replaced
Seized front caliper piston - replacement caliper options IFD933 5th gen T4Rs 16 07-10-2022 01:00 PM
brake rotor/caliper/pad replacement - caliper piston, too? amheck 4th Gen T4Rs 16 11-08-2017 09:29 AM
Brake caliper question - which caliper mfg doesn't lock up? bergs 4th Gen T4Rs 6 03-14-2015 09:18 PM
Caliper rebuild...torque settings for caliper halves squabeggz 3rd gen T4Rs 0 07-24-2014 11:08 PM
Any 01-02 have abs ecu failures? xspsi6 3rd gen T4Rs 2 06-19-2014 03:51 PM
