02-14-2023, 05:50 PM
12 volt fridge connector upgrade.
It's been sometime since Ive done anything to my 4R, but its time for some upgrades. Making the leap to an electric fridge and was wondering what others have done to upgrade from the cigarette style connector? The plan is to run 10 AWG wire to the rear.
02-16-2023, 12:08 AM
Real Name: Keith
Real Name: Keith
I have been using a National Luna Portable Power Pack (basically a battery box with a smart switch to engage/disengage from the vehicle battery) for about 10 years now. The PPP gets a large diameter 6 square mm (about 4 gauge) line running from the underhood battery. The PPP has both a standard 12V lighter socket and a so-called Hella connector socket. The standard lighter plug on the Engel fridge cable worked fine for years...it never fell out, even on rough road driving, but finally I switched it to the less-likely-to-fall-out Hella connector.
My impression: Seems like 10 gauge would probably be fine, 8 gauge would be better, 6 gauge even better, etc.
02-16-2023, 01:06 PM
No 120 plug in?
2019 Nautical Blue SR5 Premium
Retired Wildlife Biologist
"Dry side" of Washington
"Virtus Junxit Mors Non Seperabit"
02-16-2023, 09:07 PM
Originally Posted by BearBio
No 120 plug in?
No this is the ARB style electric coolers.
02-16-2023, 10:38 PM
No 120 plug in?
Its more efficient to run the fridge off DC power if possible... eliminates the conversion losses from the 120v AC inverter.
02-17-2023, 02:37 AM
Real Name: Keith
Real Name: Keith
My 2013 Engel has built-in 120V AC capability. In fact, if both the 12V DC and 120VAC cords are attached, it switches automatically to 120VAC when 120 VAC is supplied. Good for battery power when moving, shore power when parked at home.
02-18-2023, 01:29 PM
I run mine off the 120v plug in. It is a pain to remember to turn it on each time you start up but it has worked fine on several long trips to SoCal, AZ and once home via the Rockies.
02-20-2023, 02:37 PM
It should be running 24/7... you should have DC plugged in as well so runs off battery when the engine is off, or use an external battery pack.
I dont know what fridge you have but I've never had to remember to turn it on. It should go back to its last state when power is restored. It should also prioritize AC over DC and switch between the two sources automatically.
02-20-2023, 03:06 PM
He may be talking about the ON switch for the AC outlet located in the back of the 4Runner.
Side note/Story: I recently took a week+ trip to Death Valley. I powered my Iceco fridge off a 1000 WH Grecell Power Station. Plugged the power station into the AC outlet. The power draw tripped the circuit breaker and shutoff power to the power station. What a pain!!! I had to rearrange how I had everything packed so I could use the DC outlet instead. Once I got that squared away, it all ran flawlessly.
02-20-2023, 03:30 PM
Right on... that makes sense.
02-20-2023, 03:55 PM
Real Name: Rob
Real Name: Rob
Regarding connectors, I use a couple different kinds depending on the use-case.
For low power (~10A) temporary applications, I like to use SAE connectors for both interior and exterior. There's plenty of off the shelf panel mount solutions, including with dedicated switches, that can look pretty slick and I feel like you can get SAE related connectors pretty much anywhere. It also has respectable holding strength and are usually splash-resistant enough.
For medium and high power temporary applications, I'll usually use appropriately sized Anderson connectors. You can even get panel mount outlets to install in your vehicle's cargo area or wherever you want.
Just my 2 cents. Post a pic when you choose a solution!
'86 4Runner 2.4L 4cyl 22RE
'06 4Runner 4.7L 8cyl 2UZ-FE
02-21-2023, 01:30 PM
120v 4Runner switch - Yahoo Image Search Results
02-21-2023, 02:45 PM
One other side note, the outlet would work until I shifted out of either P or N. Once I tried to drive, it would shut off. Kind of a useless outlet for my purposes.
02-22-2023, 01:15 PM
Yeah, you have to remember to turn it on once you start driving. Is a bit of a pain. On the other hand, you can take it into your room and plug it in. In my case, I have insulin to keep refrigerated.
02-22-2023, 01:55 PM
No, that won’t work either. I tried that but it kept shutting off. I was on a week + Death Valley camp trip, so the 4Runner was it. Apparently the power station drew too much power. Only option that worked was using the DC cigarette lighter plug.
