Old 05-03-2023, 09:50 AM #1
4skrunner 4skrunner is offline
4skrunner will become famous soon enough 4skrunner will become famous soon enough
Help me fix my drawer system
Ok so I recently replaced my 3rd row with a drawer system that I made. It’s been working fine for off-roading and daily driving but had a pretty big issue when I had a bunch of stuff loaded on it a couple weeks ago for a camping trip. The dang thing wouldn’t open…. The weight that was sitting on the top board was all resting on the drawer faceplate and It was nearly impossible to open. I thought the aluminum angle a attached to the front of the top board would offer some rigidity and prevent this but I was proved wrong.
Any suggestions? There is nothing supporting the middle of the top board as it’s 1 large drawer. I’m thinking I should have done two drawers so there would be a support in the middle but I’m a little past that… and would rather not redesign everything and buy more parts. What do you think…
4skrunner is offline   Reply With QuoteReply With Quote
Old 05-03-2023, 11:53 AM #2
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
What about a frame the size of the top, all the way to the edges, made of 2x4s, with plywood screwed to the top of the frame, like another shelf almost? You could even leave out the 2x4 that sits over the aluminum front, and just use three 2x4s and the plywood. The weight of what's on top would then rest on the three sides of your drawer unit, not on the front. And the frame could just rest on what you already have, no need to screw them together. So you could just lift it off and leave it at home most of the time. Plywood not depicted in this crude pic, but imagine not being able to see the frame due to the plywood.
Help me fix my drawer system-frame-jpg
thennen is offline   Reply With QuoteReply With Quote
Old 05-03-2023, 05:05 PM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Aluminum angle is not very strong, I would try replacing it with steel angle iron and paint it.
I build custom cabinets for a living, other than a stronger angle I don't know how to solve your issue, hopefully the steel angle will work.
2004 Limited V8
Old 05-03-2023, 05:23 PM #4
rumfoord's Avatar
rumfoord rumfoord is offline
rumfoord is on a distinguished road
rumfoord's Avatar
I broke mine into 2 separate drawers with a middle piece providing additional support.
rumfoord is offline   Reply With QuoteReply With Quote
Old 05-03-2023, 05:23 PM #5
That would definitely work but I little more than I want to do. I don’t want multiple pieces to move around.
Old 05-03-2023, 05:24 PM #6
I’m thinking steel angle next ooorrr a C channel over the edge. Instead of just the angle. Gotta see what I can find that fits nicely.
Old 05-03-2023, 06:54 PM #7
Real Name: Skip
Real Name: Skip
Another thought is to cut down the drawer face a bit to give more clearance when it sags from weight, even with the steel angle it's still go to sag some when there's weight on the top.
2004 Limited V8
Old 05-03-2023, 07:50 PM #8
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
Was it resting on just the faceplate?
If it moves freely after clearing it, I would also recommend
reducing the faceplate top edge and adding some oval
cutouts for your hands. Give you a bit more pulling power.
Only other idea I had was raising the top surface and adding a
bunch of 1/2"x.120" angle iron spanning the whole box laterally.
Kind of a corrugated surface to add rigidity.
side view
_________________ top surface plywood
^^^^^^^^^^^^^ angle iron
------------------------ original box
Does raise whole surface and add some weight,
but just spit-balling without a complete redesign..!
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 05-03-2023, 10:01 PM #9
thennen's Avatar
thennen's Avatar
Well, it would actually be just one piece, but I get it.
Old 05-04-2023, 04:30 PM #10
lewdog998's Avatar
lewdog998 lewdog998 is offline
lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold lewdog998 is a splendid one to behold
lewdog998's Avatar
No need for complicated reinforcement. Just screw a single eye bolt into the center of the top. When you need to open, just run your winch line through a series of pulleys to the ceiling above the eye bolt. Attach the line to eye and just a little tug will take the weight off the top and the drawer will be free.
here is a crude design
Help me fix my drawer system-tempfileforshare_20230504-153131-jpg
2020 TRD Pro in Super White
RCI full alum skids - C4 Fab sliders-Diff breather mod-Upper grill hidden light bar- Auxbeam switch panel- DD reverse / turn light LED mod - Front Runner 3/4 Rack - 285/70 Dura tracs - Maxi Trac onboard air - Eibach TRD Pro lift springs - Front Runner 3/4 rack - Hefty Fabworks Lo-pro bumper - Warn VR Evo 12S. Dirt King UCAs
Man is born free, yet he is everywhere in chains....
lewdog998 is offline   Reply With QuoteReply With Quote
Old 05-04-2023, 05:40 PM #11
Thanks for the idea. I just dropped 5k on bumper winch and a bunch of pulleys. Hopefully your idea works! Fingers crossed!
Old 05-05-2023, 09:55 AM #12
lewdog998's Avatar
lewdog998's Avatar
Your very welcome.....having been previously married for 18 years you have to come up with creative ideas to justify purchasing "toys" and other things you may not necessarily need. The old "this makes it safer or it helps fuel mileage" works 90% of the time. In your case..."honey, last time i pulled the drawer out I strained my back...."
Old 05-11-2023, 11:05 PM #13
BlairB's Avatar
BlairB BlairB is offline
Real Name: Blair
BlairB will become famous soon enough
BlairB's Avatar
Real Name: Blair
If it was me I would just cut back the edge of the top piece and make a new faceplate that is slightly taller so it still has a clean look.
Also, throw a big handle on there. It helps opening a heavy drawer!
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
BlairB is offline   Reply With QuoteReply With Quote
board , drawer , middle , system , top
New DIY Drawer System Coming for 5th Gen diy_overlanders 5th gen T4Rs 21 01-22-2022 12:54 PM
FS - 3rd Gen DIY Drawer System - San Diego, CA diy_overlanders For Sale: T4R Items 2 08-10-2020 08:54 AM
New DIY Drawer System Coming diy_overlanders 3rd gen T4Rs 1 06-05-2020 03:50 PM
Drawer System blight1234 4th Gen T4Rs 57 02-20-2017 02:57 PM
