Old 05-17-2023, 08:08 PM #1
gilli8 gilli8 is offline
gilli8 is on a distinguished road
TPMS for new wheels
i've done a little researching and my question is : what are you guys using for valve stems when you upgrade wheels? i've seen people say they use OEM replacements from t!re r@ck with short learning/calibration time and no problems. i am going with TRD pro gray rims with black lug nuts and saw a post saying that black rubber valve stems used on corolla's will work. your thoughts or experiences? i just want to buy once, if i buy the wrong ones and have to rebuy and remount that would be a bad thing.
Thank You
gilli8 is offline   Reply With QuoteReply With Quote
Old 05-24-2023, 07:30 AM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
if you want to save a few hundred bucks, you can bypass the tpms system, just check your pressure regularly when you do fill ups or general maintenance.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 05-24-2023, 10:03 AM #3
ArthurKotb's Avatar
ArthurKotb ArthurKotb is offline
Real Name: Rich
ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about ArthurKotb has a spectacular aura about
ArthurKotb's Avatar
Real Name: Rich
Won't the TPMS sensors fit the new wheels? If you can just transfer the sensors then there won't be any issue, but they will have to fit or it won't work.
Toyota uses Denso TPMS sensors, or at least they have in the past. Most shops don't have the software to be able to write Denso IDs back to the ECU and the dealerships charge a lot to do it. You would have to use the tire shop's sensors and let them write the new IDs into the ECU. Newer Toyotas might be able to do this procedure themselves.
Rich
2004 V8 4Runner 140K+ miles
Kentucky
ArthurKotb is offline   Reply With QuoteReply With Quote
Old 05-24-2023, 11:21 AM #4
Yamahamer Yamahamer is offline
Yamahamer is on a distinguished road
My understanding is that the TPMS sensors are different depending on what year your 4Runner is. For my 2022 I went to autoparts.toyota.com to see which ones fit my machine, and then bought them from an on-line Toyota dealer with a good price.
Have you checked your owner's manual regarding how to get your 4Runner to recognize a new set of sensors? There is a procedure outlined in the manual, at least for my 2022 model, called "Registering" and "Initializing" a new set of sensors. I installed my sensors myself; I followed the procedures outlined in the owner's manual and they worked just fine.
Yamahamer is offline   Reply With QuoteReply With Quote
Old 05-24-2023, 11:55 AM #5
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Thank You
Napa has replacement valve stems that will work with your OEM sensors. I installed a whole set on a GX470 with some aftermarket wheels a few months ago.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 05-24-2023, 03:48 PM #6
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
Something to consider when swapping wheels how old are your current sensors and how long are they expected to last.
In my case it was easy to switch the existing sensors over to the new rims, but tires are lasting longer than the existing sensor batteries so with 2 batteries down I'm looking at having the all tires unmounted to replace the full set of sensors. Kinda wishing that I had swapped them when I was putting on the new Tires/rims
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 05-24-2023, 07:41 PM #7
Boort
well my plan is to get a set of MT baja boss's and some method 316 gunmetal to put on my MGM ORP which is on a train last report. so i won't mess with the factory rims/tires, keep for backup or sell???
Old 05-24-2023, 11:23 PM #8
ArthurKotb's Avatar
Real Name: Rich
ArthurKotb's Avatar
Real Name: Rich
Boort
Check with the shop where you bought your last set of tires. The shop I used (big name in this area) said if I had bought my tires from them they would install new sensors for free. Doesn't hurt to ask.
Rich
Kentucky
Old 05-25-2023, 12:28 AM #9
Boort's Avatar
Boort's Avatar
Cool, I swapped my old rims/tires to my 1st Gen Tacoma. and kept the Tacoma rims/tires for winter driving. I'll probably decide to sell off the old rims at some point since I doubt I'll have reason to go with the Tundra big brake swap on the little truck.
Boort
-- 2006 4Runner v8
Old 05-25-2023, 12:30 AM #10
Boort's Avatar
Boort's Avatar
Thanks for the heads up. I'll give them a call and see if they are willing to do the swap.
Boort
-- 2006 4Runner v8
Old 05-25-2023, 03:31 AM #11
TK-422's Avatar
TK-422 TK-422 is offline
Real Name: Chris
TK-422 will become famous soon enough TK-422 will become famous soon enough
TK-422's Avatar
Real Name: Chris
I recently replaced my 4 tires and used the best old tire for the spare No TPS needed). My 4Runner is a 2015 so the sensors were well at the end of life.
I went from 275 to 285. When the 275 were installed I did not have the sensors replaced since they were not that old at the time.
So now I have 4 new 285 tires on my 4Runner with new sensors and an almost new 275 for the spare without one.
I bought and installed them thru Americas Tire ( In So Cal, Discount tire in other places). They charged me about $30 for new sensors + programming each tire.
I thought that was reasonable.
<a href=http://www.tophersworld.com/imagesb/tk422_signature.jpg target=_blank>http://www.tophersworld.com/imagesb/tk422_signature.jpg</a>
"I hope yours took a bath once in a while, kid. This guy's armor smells like he lived in it."
―Han Solo to Luke Skywalker, while donning TK-422's armor.
TK-422 is offline   Reply With QuoteReply With Quote
Old 06-06-2023, 08:11 PM #12
jfon jfon is offline
jfon is on a distinguished road
We have sets of snow tires mounted on wheels for our cars. When swapping out for winter we just live with the TPMS warnings until the all-seasons go back on.
I lived for several decades keeping an eye on my tire pressures without this tech. It's nice but superfluous to my needs.
jfon is offline   Reply With QuoteReply With Quote
Old 06-06-2023, 10:25 PM #13
BearBio's Avatar
BearBio BearBio is offline
BearBio has a spectacular aura about BearBio has a spectacular aura about
BearBio's Avatar
I agree. When I switched tires and rims, my sensors have never worked right. Went back twice and they said they are all "OK". Discount tire will check your pressures without you getting out of the car. I do that before any trip.
2019 Nautical Blue SR5 Premium
Retired Wildlife Biologist
"Dry side" of Washington
"Virtus Junxit Mors Non Seperabit"
BearBio is offline   Reply With QuoteReply With Quote
black , buy , stems , valve , wheels
TPMS and new wheels Monty87ls 4th Gen T4Rs 14 08-14-2021 12:59 PM
Swapping SE wheels for LE wheels - TPMS question T4R # 5 4th Gen T4Rs 14 06-25-2015 09:22 PM
tpms to TE wheels oljedi11950 4th Gen T4Rs 0 12-05-2013 03:31 PM
tpms to TE wheels oljedi11950 Engines / Suspension / Wheels / Tires / Audio / Accessories 2 11-29-2012 07:48 PM
Wheels without TPMS? traffic626 5th gen T4Rs 3 05-04-2011 12:39 PM
