Old 11-04-2023, 08:50 AM #1
BoulderT4R BoulderT4R is offline
BoulderT4R is on a distinguished road
LED Turn Signal Bulbs
I’ve seen a number of older cars (not just 4Runner) with LED turn signal bulbs in the OEM light housing. Anyone have experience with these? Any specific brands that are recommended?
I bought a used 04 4Runner and have to change a burnt out bulb so was debating going the LED route.
1999 T4R Highlander
4x4
All Stock
BoulderT4R is offline   Reply With QuoteReply With Quote
Old 11-04-2023, 02:22 PM #2
3ToyGuy 3ToyGuy is offline
Real Name: Patrick
3ToyGuy is on a distinguished road
Real Name: Patrick
If it were me, I would. I replace failed tail lights, brake lights, etc, with LED's as they happen. Under normal usage, they should last beyond the rest of the truck.
Just my opinion.
Pat☺
3ToyGuy is offline   Reply With QuoteReply With Quote
Old 11-04-2023, 11:17 PM #3
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
even if you change out to led bulbs, 7440 for signals in the rear, I would still change out the flasher to an led compatible flasher relay. its about 15-20 bucks and its located in the rear of the inside fuse box.
changing the relay will make it flash at the normal rate, no more hyper flash.
only thing that's going to change is your lights wont flash with the factory keyless.
I don't use that since I have an aftermarket alarm/remote start system.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 11-05-2023, 11:06 AM #4
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
I’m definitely a fan of LED but you need to do it right. I’ve seen too many issues with cheap stuff from Amazon, eBay, Autozone, etc that are either not very bright, flicker, and/or burn out quickly. Diode Dynamics is a good brand.
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 11:09 PM #5
jtgoesfast jtgoesfast is offline
jtgoesfast is on a distinguished road
I just got new Ebay black headlight housings, and decided to upgrade to LED blinkers as the stock units were too dim. I bought them from AuxitoLED for ~$45, couple months in, so far so good. They've got a cooling fan and built in resistors to not have the fast flash. Super bright as well.
jtgoesfast is offline   Reply With QuoteReply With Quote
4runner , bulbs , led , signal , turn
Better turn signal bulbs? cognus 4th Gen T4Rs 11 10-27-2019 02:08 PM
LED Turn signal bulbs gigerunner Classic T4Rs 28 12-13-2014 01:43 PM
Brightest LED Turn Signal Bulbs akaknowlesy 4th Gen T4Rs 28 03-11-2012 04:04 PM
Clear bulbs for turn signal Clemsonfan15 3rd gen T4Rs 0 06-20-2010 12:12 AM
Turn signal bulbs teamitazura22 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 05-26-2006 04:35 AM
