Old 01-05-2024, 03:38 PM #16
Grug556's Avatar
Grug556 Grug556 is offline
Grug556 is a jewel in the rough Grug556 is a jewel in the rough Grug556 is a jewel in the rough
Grug556's Avatar
Originally Posted by mrblah View Post
1. 3 to 4 min each tire.
2. Never had a issue. 100 PSI
3. Shrockworks mount t.
Thanks MrB appreciate the detailed reply. Thanks to the rest of you guys. Looks like I am gonna go all in ...and get the single compressor. I got time to kill waiting for it to air up so thats ok.
Grug556 is offline   Reply With QuoteReply With Quote
Old 01-05-2024, 07:55 PM #17
FoundedSine14's Avatar
FoundedSine14 FoundedSine14 is offline
FoundedSine14 will become famous soon enough
This is what I use
ALL-TOP Air Compressor Kit https://a.co/d/enebXB5
It airs up all 4 from about 12psi to 35psi in about 15 minutes, maybe less. Can't beat it for the price
2008 SR5 | Build Thread
2006 AutoX Camry | Build Thread
FoundedSine14 is offline   Reply With QuoteReply With Quote
Old 01-05-2024, 10:27 PM #18
mrblah's Avatar
mrblah mrblah is offline
mrblah's Avatar
I also wanted to add, that it is tempting to install it on the driver side behind the battery, and next to an accessory panel. I did this previously and it was a wiring mess and difficult to do any kind of maintenance in that area (adding lights and accessories) because the accessory tray, compressor, wiring harness, made it difficult to re-route wires.
What i ended up doing was move the compressor behind my air intake, and left the accessory panel behind the OEM battery location. Way happier doing it this way. I can add accessories without having to disassemble everything, and lots of room around the compressor to let it cool down.
Anyways, here are some pics of the shrockworks mount and a bunch of add on accessories for the compressor:
0: vacuum pump relocation kit (next to compressor)
1. locker actuator.
2. Wits end pacifier and safety wire.
3. quick disconnect brass chuck.
4. battery box in front of intake
cheers!!!
Compressors anybody?-thumbnail-199-jpg  Compressors anybody?-thumbnail-200-jpg
Old 01-08-2024, 10:17 AM #19
Grug556's Avatar
Grug556's Avatar
Originally Posted by Humble Leader View Post
I know you're asking someone else these questions but perhaps I can give some perspective as well. I spent a lot of time researching air compressors and mounts
2. Has the single ever been unable to fill a tire? Or is there a max pressure it cant fill past? max PSI is 100. for automotive use you should have no issues.
3. What mount did you use? I assume no add on tank? no add on tank. I used an LFD offroad stainless steel mount that goes on the passenger side. I ran an m6 up through the wheel well to create a stud on a weld nut that was already there and mounted on there with a nut vs. using a bolt. made the install much easier and I like that set up better
4. What switch gear are you running to activate it? switch pros. arb single and dual are so easy to wire. pos and neg to battery and switch wire (only 1 wire) to positive on the switch panel. that's it
5. Any other details about install? I have the fuse for the compressor up along the wiring loom near the firewall. tried to keep is as far from the hot engine as possible
I honestly don't think the tank is needed unless you have huge tires or are running lockers or air tools or something. I have had my arb since 2022 and it's been great. I don't use it all the time. but it has never failed me. when it comes to engine heat, I use the air chuck on the compressor so the hood will always be open. I've never had a heat issue but I also don't use my compressor all the time. I actually use it to clean off my wood working projects after sanding so it does run for quite some time every now and then
also I've seen a lot of unique mounts for the air chuck. if you are plugging into the air chuck or routing - make sure the first 6-12" off the compressor is stainless hose. the chuck gets hot and can melt hoses under heavy use. I didn't do anything fancy. flexzilla lines with an 18" leader stainless steel. get's the job done.
I have a portable viair 400A (auto shutoff). it's mounted inside a carrying case. it's a great compressor as well but it is nice having the arb which is more compact in the vehicle. if my single breaks I may upgrade to a double since I have the room and the price is good. but for me and for now the single is plenty for my uses
here is the LFD mount I used. it works for single and double so upgrading is easy
Air Compressor mount for ARB Compressor – LFD Off Road
Thanks Humble appreciate it
Old 01-08-2024, 10:19 AM #20
Grug556's Avatar
Grug556's Avatar
1. locker actuator.
cheers!!!
yeah I was out on the weekend measuring stuff. Im gonna go with behind air intake as well. Lots of room. To bad about Shrockworks, I have some of their stuff already.
Thanks for the pics!!! They help a ton!
air , arb , compressor , max , spod
Compressors? MrBob Off Topic 16 04-29-2019 05:49 AM
--ARB Compressors GB-- CLOSED** Babyjake16 Group Buys 17 07-05-2018 07:09 PM
ARB Compressors Awz Classic T4Rs 4 06-11-2013 07:58 PM
Portable air compressors Bobby Off-Roading 18 12-07-2005 08:00 PM
