Old 02-26-2024, 07:02 PM #1
Harlock's Avatar
Harlock Harlock is offline
Harlock will become famous soon enough
Harlock's Avatar
Roof Rack goes Brrrrrrrrr
When I've driven in below freezing weather recently, the front wind fairing on my Victory 4x4 roof rack will make a loud Brrrrrrr noise. Like most aftermarket racks, the faring has a rubber gasket on the underside between the roof and the rack. Would it be better to move the fairing closer to the roof for a tighter fit, or further away so there's a small air gap between to the roof and the fairing?
No matter where you go, there you are.
2007 4Runner SR5 4WD | 4.0L V6 1GR-FE VVT-i
Philips Ultinon LED Interior Lighting, Weathertech FloorLiners, Toyo Open Country AT3 265/75/R16, Victory 4x4 Roof Rack, RacksBrax Brackets, ARB 2500 Awning & Awning Room, IceCo JP42 Refrigerator, Anker 757 LifePO4 Generator, Renogy 100w Monocrystalline Solar Panel, JVC KW-V660BT Head Unit
Harlock is offline   Reply With QuoteReply With Quote
Old 02-26-2024, 07:48 PM #2
crawlingjunk's Avatar
crawlingjunk crawlingjunk is offline
crawlingjunk will become famous soon enough crawlingjunk will become famous soon enough
Maybe the rack is cold?Roof Rack goes Brrrrrrrrr
crawlingjunk is offline   Reply With QuoteReply With Quote
Old 02-26-2024, 08:48 PM #3
ThorRides's Avatar
ThorRides ThorRides is offline
Real Name: Todd
ThorRides is on a distinguished road
ThorRides's Avatar
Real Name: Todd
Closer equals less noise.
'05 T4R Limited V8 with 4" lift
My Ride
ThorRides is offline   Reply With QuoteReply With Quote
Old 02-26-2024, 09:19 PM #4
Boort's Avatar
Boort Boort is offline
Boort will become famous soon enough Boort will become famous soon enough
Boort's Avatar
I had a similar issue with my sherpa back when I first installed it. Here are the things that I did while working to eliminate the noise:
I'm assuming that you have already checked that all connectors are tightened to spec and that any washers are installed and in good repair.
Besides lowering the gap as others have suggested (which may switch the sound from a BRRRRRRrr to a Whistle.) Look to see if it is possible to move it back or forward a bit so that the air coming off the windshield hits it in a different location. Moving back should have it hit a bit higher up and reduce the amount of air boing under and behind the front lip of the deflector. (or forward so that it hits lower and is not pushing back on the top edge causing a wobble.)
Do you have a bug deflector on the hood? if so try taking it off.
If this does not work reach out to Victory and see if they have any other suggestions or adjustments to change the angle of impact. Possibly shimming out the bottom to give the deflector a sharper angle will slipstream the air flow more.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 02:33 PM #5
GhostRing's Avatar
GhostRing GhostRing is offline
GhostRing has a spectacular aura about GhostRing has a spectacular aura about
GhostRing's Avatar
Absolutely get the fairing to make contact with the roof. The lower edge is likely buffeting in the wind since there is no support directly behind it.
Re-drill/slot the side plates to re-locate it if you have to. Add some 3M/helicopter tape to the roof to protect the paint if it's not there already.
This happens every so often with platform fairings regardless of manufacturer, so don't fear that you got a lemon... Also, is the fairing cut for a lightbar?
If there is no light installed it can potentially make the first crossbar the wind's main point of contact and it could start making noise.
Build Etc...
If it ain't broke, fix it 'til it is.
GhostRing is offline   Reply With QuoteReply With Quote
Old 02-27-2024, 04:36 PM #6
Harlock's Avatar
Harlock's Avatar
[QUOTE=crawlingjunk;3830230]Maybe the rack is cold?Roof Rack goes Brrrrrrrrr
It's definitely freezing!
Boort
The rack is dead silent at all times except when temperatures drop below freezing. All bolts were installed with washers and loctite. No bug deflector.
I have that helicopter tape on the roof under the rack. There's no lightbar cutout.
Sounds like you guys are indicating the metal may be shrinking in really cold weather just enough to start flexing.
Old 02-27-2024, 04:42 PM #7
hoppyjr hoppyjr is online now
hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about hoppyjr has a spectacular aura about
Well, shrinkage in cold weather is a very real thing.
hoppyjr is online now   Reply With QuoteReply With Quote
fairing , gasket , rack , roof , underside
Remove 2021 TRD pro roof rack and replace with standard roof rack kitesurf 5th gen T4Rs 2 03-11-2022 09:00 PM
2019/2020 Pro Roof Rack To SR5/Off-road Roof Rack LRT 5th gen T4Rs 19 02-05-2022 03:45 PM
Roof rack delete strips...where to buy...or trade for OEM roof rack?? FLYNAVY53 3rd gen T4Rs 14 01-07-2022 08:59 AM
Wanna trade my roof rack for your roof rack covers? Qyota 3rd gen T4Rs 10 05-07-2013 10:23 PM
TRADE: Silver roof rack for Black roof rack. trijicon Classifieds - buy & sell (no commercial ads please) 0 04-19-2006 02:38 AM
