02-29-2024, 10:53 AM
Real Name: Dave
Real Name: Dave
It will be interesting to see what broke.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
02-29-2024, 11:14 AM
Classic CV break is my guess. Bouncing or quick loss and gain of traction with wheel spin and kaboom. Broken CV on one side or the other will just spin with the open diff looking like loss of drive up front.
This is why I dont wheel in winter. Love the TFL guys and they dont go easy on the reviews but this breakage seems pretty weak Would think they would be able to diagnose what happened on the trail pretty easily.
02-29-2024, 11:52 AM
I think that the son of the one of the TFL guy is the one that is knowledgeable.
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
02-29-2024, 07:09 PM
Real Name: Dave
Real Name: Dave
Though their intent was to put the rig to the test, I think it was foolish to take the truck out in even that little bit of snow and ice and with street tires.
It appears that the Colorado had at least A/T's, as he was able to back into the rough spot and still pull the Tacoma. Depending on what package the Colorado had, it may have had a front locker, which definitely would help. I didn't watch the entire video, just started at the suggested time stamp and followed it to the end.
Not sure why Toyota is reluctant to offer a front locking diff in their off road models. If it was a broken CV axle, a locker in front would retain at least 3WD instead of 1WD unlocked in back and 2WD locked.
Dave
2018 4Runner SR5
02-29-2024, 10:11 PM
Lockers are really hard on axles. And if you have IFS and thus CV's it's going to be doubly hard on them. So if you have weak CV's, lockers will destroy them, easily. Even weaker live axles will not stand the stress of lockers. Lots of Dana 30's have found that out the hard way.
03-01-2024, 12:31 AM
This seems like a transfer case issue. Zero wheel spin from the front. Beyond the initial sound no additional noise from the front. This doesn't make a ringing endorsement for new generation Tacoma or 4runner. The Tacoma was running empty with no additional weight. TFL usually runs street pressure which means less traction. The bump They gave to get onto the rock was very minor. Imagine the Overlanders adding 1500lbs of stuff. Stress on the TC would be much higher. Curious to find out the cause and will Toyota warranty the damage?
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
03-01-2024, 01:58 PM
Pot metal parts from China, no doubt.
That shouldn't happen on a brand-new Toyota.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
03-01-2024, 04:05 PM
Originally Posted by Thai
Hopefully, this is a defective mechanical part……….but if not, then LC250 is basically a paper tiger….
How so? I would think it's more of a concern for the upcoming 4Runner?
03-01-2024, 04:30 PM
The Land Cruiser, 4Runner, Taco, and GX550 all share the same platform. So yes, it is a concern for all.
2023 Lexus GX
Lets Go Brandon!
03-02-2024, 11:50 AM
You're probably right, I just never viewed the Tacoma to have the same durability as a Prado based build, like the GX for instance.
I have no idea what the 6th generation 4Runner is going to be but you do hear a lot that it will be based on the Tacoma. Thinking it might not be as durable as a GX overland or the 250. We'll see.
03-02-2024, 12:08 PM
I thought it was a electrical actuator problem, but since we heard a pop, it could be the actuator releasing out of gear and the gears popped, thus since it stopped holding an electrical charge it would no longer put the gears back into place. Actuator failure, just a thought.
2024 4 Runner Premium TRD Off Road
03-03-2024, 02:52 PM
Toyota's PR team is in crisis management right now...HA! serves them right, what is this BS
2018 Toyota 4Runner SR5
2024 Chevrolet Silverado 1500 LT (just bought and negotiated $8.2k off MSRP, I brag about it every chance I get)
03-03-2024, 05:31 PM
Wowzers! Does not bode well for Toyota. Will be interesting to follow this and see what exactly happened and the point of failure. Weak/poor materials? Bad engineering? Cost cutting?
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
