Old 03-20-2024, 03:40 PM #1
Deej101 Deej101 is offline
Deej101 is on a distinguished road
Steering column tilt not holding (2001)
I need a quick answer so no time to search right now, hoping this is something obvious.
Yesterday while accessing some wires in dash, had to remove parts of dash around steering cokumn, and after putting things back, the tilt function no longer locks--so steering wheel just flops around. I had to drive it last night that way, and I need to drive today so no time to take everything apart again searching for the problem.
2001 SR5.
Thanks in advance for any help.
Deej101 is offline   Reply With QuoteReply With Quote
Old 03-21-2024, 02:57 PM #2
Solved
So after pulling the plastic covers off, discovered that the plastic "Tilt Lever Link" had a piece broken off, which allowed it to slip out of the hole on the "Tilt Lever" rendering the tilt lever useless (the broken link should connect the tilt lever to the "Tilt Lever Retainer" which slides back and forth engaging/releasing the gears/teeth that control the tilting function).
Since I always keep the wheel up, I just won't use the lever, and if I must use it (for access purposes) at least now I know the issue and can easily reset it after removing the covers. Maybe one day I'll replace the part.
Hope this info helps others who may find themselves in a similar situation.
dash , drive , steering , tilt , time
replacing intermediate steering column U joint - loose steering jrm 4th Gen T4Rs 4 09-15-2017 05:28 PM
Can't disconnect steering column from steering rack variablevalve 3rd gen T4Rs 8 05-25-2017 01:30 PM
New Dashboard Steering tilt not working rsmith0399 4th Gen T4Rs 2 12-29-2016 04:55 AM
Steering Wheel Alignment w/ Steering Column UncleOOPS 3rd gen T4Rs 2 07-13-2012 04:17 PM
4runner tilt steering johnloomis 4th Gen T4Rs 0 07-03-2004 10:07 PM
