01-13-2025, 12:04 PM
Real Name: Patrick
Real Name: Patrick
Stealership strikes again
So, I broke the key where the plastic piece inside the fob housing holds the actual metal part that comes out on my wife's 4Runner... I tried snapping it back together, but it didn't hold. I had heard or seen somewhere on the interwebs that you can call the Stealership and give your VIN and they can order you a replacement. So I called up their servicing dept and they made an appointment to get me a new key. I promptly scheduled the time off work and headed down to get my key either fixed or replaced. I'm also due for an oil change, so I'm thinking if it's not too bad, I'll throw that in.
Here's where it all goes to hell...
I pull up for my appointment, the service guy comes out, scans my VIN inside my door frame and checks my name. I reaffirm to him why I'm there and he then tells me that he needs to go check to see if they even have the key in stock. (Here's where I start to get pissed)... He comes back about 10 min later to tell me that they don't have the key in stock and it would have to be ordered. I would have to pre-pay to order it ($277) and that it may take up to 3 days to arrive.... I go, "Wait, why did you guys make an appointment with me to do this, and tell me the whole process would take about an hour, when you don't even have the part in stock?!?"... He goes, "Yeah, do you know who you spoke with?" I said, "I called your servicing department and you guys scheduled this appointment. I took the time off work and clearly you have my appointment booked. Now you're telling me it was a whole waste of time and you don't even have the part?" He goes, "I think you probably spoke with our phone servicing team who answers calls when we're busy and they booked you." I said, "That's BS! When they answer the phone as SERVICING DEPT, how are you supposed to know if they actually work there or not?!?"
So now I'm pissed, but I'm trying to calm down and I go... "Ok, so if I order this, it's $277. Is that $277 for everything?" He goes, "No, it's $277 for the key plus tax, then an additional $159 to program it to your car." So now we're in the $450 range assuming there's nothing else added... The crazy part is that in all honesty, if they had the part there in stock and could've done the whole thing in an hour like I was initially quoted, I probably would've done it... Here's the funny part... As I'm in a fit of rage and about to drive off, the guy I'm talking to goes, "I can give you a name and a number of a locksmith guy that we use here at the dealership who can probably help you."... At this point I had nothing else to lose, so I call the guy and tell him that I was referred to him from the Toyota dealer. He says he can come out in an hour and he'll do the whole thing for $140 cash. I said, "DONE!"
So, assuming this ends well and I'll know here in less than an hour. I'll have a rave review for the locksmith. While I'm still pissed at the dealership, I suppose that in the end I should be thankful that I was referred to a guy who can do it and apparently does it for the dealership regularly.
This also got me to thinking... If this guy does this whole thing for the dealership for I'm guessing the same cost or in the neighborhood of what I'm paying, then that's a hell of a markup for the Stealership.
Proud Toyota owner since 1994
01-13-2025, 09:59 PM
Real Name: Ron
Real Name: Ron
They didn't get that "name" for nothing! But that is a crazy story! Oh, by the way, if you just .... REALLY!?
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
01-14-2025, 01:42 AM
I saved this website from a post I read many weeks ago.
Perhaps it is legit? If anyone uses it for a key please advise. It is nice to have an alternate to dealers.
01-14-2025, 11:31 AM
Ace hardware store does it as well.
01-14-2025, 09:18 PM
If you are near a Costco they work with a group called Car Key Express it's also on the Costco sight. I haven't had keys done personally but have heard from others and read other positives reviews. Most folks said far cheaper than the dealership or other locations and they handled all programming and such included if you need that.
01-15-2025, 10:11 AM
Ditto
01-15-2025, 03:49 PM
I think you will find this is pretty much how a replacement key works, the price of the key and the service dept. getting the key coded to your vehicle. As far as the parts dept. not having the correct new key that works for your vehicle, I would have checked with the parts dept. first to make sure they had the correct blank. I will say here, most lock shops can cut a new blank and code it to your vehicle, this can usually be done for less money than you pay at the dealer. Try to trade in your vehicle at the dealer and you only have one key, they will charge you for another key in the deal on your new vehicle.
2024 4 Runner Premium TRD Off Road
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
