Originally Posted by CutthroatSlam
How many ft lbs on and off is it rated for?
BL™ Brushless Motor delivers 155 ft.lbs. of Fastening Torque and 245 ft.lbs. of Nut-Busting Torque
Variable 2-speed (0-1,300/0-2,400 RPM & 0-2,000/0-3,600 IPM)
I do have a Tektron 250 ft lb torque wrench also for anything needed over 155 ft lbs fastening.
Some videos I've seen of removing the bolts on the lower control arms and for the brake calipers are a bit challenging even w a breaker bar. Thought it may be worth adding this to the tool lineup if it's powerful enough for off..
