Old 02-02-2025, 01:57 PM #1
aa040371 aa040371 is offline
aa040371 is on a distinguished road
Extracting Brake Fluid from Master Cylinder
This may only apply to Gen-4 4-Runners (which I have)? Not sure...
I notice that pretty much all How-Tos and guides for flushing/replacing brake fluid start with extracting as much of the old fluid from the master cylinder as possible through typical means like a turkey baster. In my Gen 4, though, there is a plastic funnel/filter/whatever that is essentially a choke point or obstacle that make it almost impossible to get any more than an ounce or so. Is this thing removable, or if not is there a typical/usual workaround? Thanks...
2007 4-Runner Limited, V6 w/RWD.
aa040371 is offline   Reply With QuoteReply With Quote
Old 02-09-2025, 08:43 PM #2
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
the fastest way, is have someone step on the brakes with key in on position, the pump will turn on for the rears, bleed/flush those first, but at the same time have someone under the hood to check on the level, once it hits minimum line, stop bleeding, then fill with fresh fluid and start again. bleed/flush the rear pass side then go to driver side. this way you'll have fresh fluid in the reservoir, it works for me. but you can also use vacuum method. just be sure to keep the reservoir full at all times.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 02-11-2025, 12:18 PM #3
Originally Posted by riceandpho View Post
the fastest way, is have someone step on the brakes with key in on position...
This describes basic flush process, which isn't really what I was asking about.
Old 02-12-2025, 09:44 AM #4
riceandpho's Avatar
riceandpho's Avatar
you can remove that screen and try to use a small hose to suck the fluid out. its been a while since i did mines.
Old 02-12-2025, 10:20 AM #5
Is yours a Gen4? If so are you saying you have removed that filter on yours before? Reason I am asking is that I tried tugging/twisting gently and then semi-gently on mine with no lock. The thing I am talking about looks less like a filter and more like a plastic cone, actually.
Old 02-12-2025, 11:34 PM #6
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
Can you provide photo of the cone/filter thing causing the restriction?
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 02-13-2025, 09:51 AM #7
riceandpho's Avatar
riceandpho's Avatar
you just put your fingers in and twist the filter and at the same time, you lift it up. I have a 2007 model, same as yours I would think.
if you have a vacuum bleeder, I would do the driver front. just make sure to get it close to the Min line, then add new fluid. stop making it more difficult than it already is.
driver front will get most fluid out fast, then do the traditional way with new fluid, less chance of old fluid in the system.
Old 02-14-2025, 03:54 PM #8
Thanks...I'll try again with a little more force, I guess. It just didn't seem to want to give on previous tries to the point I was scared of snapping something.
Originally Posted by Hungryhawk View Post
Can you provide photo...?
yep:
Dropbox
edit: Well, I tried. There seems to be something stoooopid going on with the "image" button and subsequent uploading image from URL provided...whatever. But URL without image tags at least displays and can be used to get to the pic. Although pic may not be very useful, IMO.
brake , cylinder , extracting , fluid , master
Brake Fluid Leak Master Cylinder Sighog Maintenance/Detailing 4 11-11-2018 05:54 PM
Brake Master Cylinder Studs cferry7 Classic T4Rs 2 05-19-2015 10:58 AM
4th Gen Brake Master Cylinder caslim 4th Gen T4Rs 1 06-27-2013 09:04 PM
2nd gen brake master cylinder KidVermicious Classic T4Rs 12 06-24-2012 10:13 PM
diagnosing Brake Master Cylinder soundstudio315 Problems & Warranty Issues 2 05-05-2009 11:44 PM
