Originally posted by jrb23
Not too bad It looks like I will have to possibly replace the front shocks. But other than that yea it was a good deal.
Why are you needing to replace the front forks??
If they are just leaking fluid, it usually only needs some new seals, fresh oil, and good cleaning of the internal components. I imagine the springs are pretty soft if you are anything above 150 lbs, so it may be smart to go ahead and plug some stiffer springs in there while you have them apart.
If you can pick up a service manual the work itself is pretty simple.
