Old 06-17-2008, 09:12 PM #1
pw1981 pw1981 is offline
pw1981 is an unknown quantity at this point
Problems with an RS3000 System
My mother-in-law has a 98 4Runner Limited with the RS3000 system installed. However, the system is no longer functional and the stealership says the "brain" box on the system needs to be replaced.
Personally, from my research, installing a Viper/Hornet Keyless System or Alarm is a much better value than replacing the Toyo part.
So my question is.... to disable the RS3000 system, do I need to do anything else other than just unplugging the box under the seat?
Right now, the system malfuntions on her on a regular basis so it needs to go either way.
Thanks for the help!
-Phil
pw1981 is offline   Reply With QuoteReply With Quote
Old 06-18-2008, 07:38 AM #2
toto toto is offline
toto is on a distinguished road
The RS3000 also comes with a special wiring harness that allows it to tap into several functions, like the door locks, the ignition, and the gear shift selector. Because it's factory, there is no cutting involved - it has mating plugs for whatever it has to connect to.
If everything on the truck operates normally just by unplugging the box, then you should be OK. I'd bet you won't get that lucky, though. If something quits working, you'll also have to remove that wiring harness and restore the original connections.
Here's a helpful page about the RS3000 that's specific to 4Runners. The PDF with the installation instructions will show you more about this wiring harness.
http://4runners.org/writeups/rs3000/index.html
2006 Limited V8 4x4, Shadow Mica/Stone
toto is offline   Reply With QuoteReply With Quote
Here's Some Help with Navigation Install petegaz Engines / Suspension / Wheels / Tires / Audio / Accessories 321 01-19-2020 11:14 PM
'01-up 4wd System (A-TRAC, VSC) and TORSEN T-3 Thai General Discussions 56 08-22-2010 07:25 PM
RANT by me: Toyota Land Cruiser/LX570 Thai General Discussions 43 08-31-2009 11:55 PM
2003 Lexus GX470 Thai Lexus GX470/460 68 07-22-2004 05:35 PM
2003 Acura MDX Thai Comparisons & Reviews 33 06-01-2004 09:07 PM
